Question about Pasquini Livia 90 Espresso Machine
When I turn on the machine it clicks off, like it has no water, but the reservoir is full
My Keurig tells me I need to add water when it is full. This is a sudden, new problem. How do I fix it? Thanks.
Turn off your machine and unplug it. Detach the water reservoir. Wait 5 seconds then repeat the steps 1 and 2. Insert the water reservoir then press the menu button and when the “Not Ready” message appears lower handle.
Sep 21, 2017 | Keurig Coffee Makers & Espresso Machines
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
Apr 24, 2016 | Keurig B60 Coffee Maker
TK68E SIEMANS Coffee machine when switched on displays the message fiillup systm pipe assy.it has a water tank that yo remove and fill which i have checked removed replaced and is full .still message...
Hi, I have a espresso machine that has a water reservoir that you fill. There is also a hose that sucks water out of the reservoir into the machine and boiler. If that suction hose is empty of water, it will not suck water out of the reservoir. The hose needs to be "primed" by filling it with water first and then inserting it into the reservoir. Maybe your message refers to that. There's also another hose that returns excess water back to the reservoir but that is not a part of this solution.
Hope that helps. Mark F
Dec 08, 2017 | Coffee Makers & Espresso Machines
I have a rancillio. The steamer works really well for about 15 seconds and then peters out???
Descale the boiler with citric acid.
  1. Turn off the machine and let it get cool
  2. Dissolve about a tablespoon of citric acid in the water reservoir.
  3. Turn on the machine and then pump about a cup of solution out of the boiler vent using the hot water switch.
  4. Turn off the switch. Close the vent
  5. Let the boiler heat up for about 5 minutes.
  6. Shut off the machine. Let the acid work for about 30 minutes.
  7. Check the level in the reservoir.
  8. Turn on the machine and then pump about a cup of solution out of the grouphead using the brew switch.
  9. Turn off the brew switch.
  10. Repeat steps 5,6, 7, 8, and 9 until the water runs clear.
  11. Wash out the reservoir.
  12. Turn the machine on. Pump a full reservoir water out the grouphead using the brew switch.
  13. Refill the reservoir.
  14. Have some coffee
Dec 02, 2012 | Rancilio Silvia Espresso Machine
How do you adjust the water level
After the first brew the machine should brew excactly the amount of water added to the water reservoir. Since the reservoir always keep half full then you should add the maximum amount you need in two steps.
Apr 07, 2012 | Grindmaster B-SAP Coffee Maker
Hi, My Solis master 5000 digital is having a problem. When we turn it on it says water tank is empty even when the tank is full. Thank you!
Check the water reservoir, if there is a float in the corner. Then that piece is not getting in contact with the reed switch in the machine. Try sliding the reservoir down the back of the machine so that it is always in contact with the back, or if the float is not rising when the reservoir is filled with water then the reed switch cannot detect the magnet in there. You might need a new float assembly.
Oct 20, 2011 | Solis Master 5000 Espresso Machine
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Not all water comes through filter
2 cups white vinegar in reservoir, run full cycle, let cool, discard vinegar. Fill reservoir with cold water, run full cycle, discard water, let cool. Repeat clear water cycle.
Jan 22, 2010 | Bunn NHB Coffee Maker
Empty light on espresso machine won't turn off and tank is full
I have the same machine. I just went on the coffee geeks website and it is easily solved. Just add a few grains of salt to the reservoir - the sensor cant detect water that is purified - strange but true as four grains and it fired up just like that.
Apr 13, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Can't get expobar office lever to start pumping water into boiler
You are right, there is no flange.Under the tank reservoir there is a switch (micro) if you lift the reservoir up you should hear the switch click on and off,.Sometimes the switch will hang up and stop the pump from coming on.Try that and let me know.
Thanks,
Sanremo
Feb 04, 2009 | EXPOBAR Office Lever
Pasquini Livia 90 Espresso Machine Logo
143 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
