Question about Emerson LC391EM3 39 in. LCD HDTV
I Have my RCA CABLE HOOKED UP INTO MY TV I HAVE A PICTURE HOWEVER I DON'T HAVE ANY VOLUME AT ALL
I JUST PURCHASED MY TV TODAY AND HOOKED IT UP .
    New Friend:
  • 4 Answers
How do you have it hooked up? RCA cables, HDMI, DVI, etc...
If you're using RCA cables (usually red, yellow, and white) check and make sure that the audio cables (red and white) are plugged into the correct sockets with corresponding colors. If you have properly connected the cables and your issue persists, then you might have faulty wires (might have a pinch which could have broken the wire through the inside) try again with different wires and see if it works. if it still doesn't work try pluging your RCA cables on different sockets (TVs usually have more than one component sockets)...make sure your red and white wires are on the same component # as the yellow wire.
Posted on Feb 16, 2014
RCA 60921 rear projection tv. Everything worked perfectly until today. It sometimes made a hissing noise on and off but nothing very loud. Today I turned on the TV and the audio works but there is no...
Bad FBT Flyback Transfomer.You need to also check the Hori output Transistor,chances are if FBT is bad then Hori output will be shorted.
Mats Electronics should have FBT 1-800-628-1118
ACME 1-800-575-9833
Jun 28, 2011 | RCA P60921 60" Rear Projection Television
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Have no sound from VCR, cable hooked up properly, picture is great. TV is brand new.
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
Aug 12, 2010 | Toshiba M755 VCR
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No picture, only sound through HDMI port
You have the video [yellow cord] on the wrong rca jack. Or a bad video cord. Should be easy to fix.
Mar 24, 2009 | Sony PlayStationĀ® 3 (60 GB) Console
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
May 12, 2008 | RCA L46WD22 Television
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Emerson LC391EM3 39 in. LCD HDTV Logo
96 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
