Question about XO Vision XO-1400 Car DVD Player
What is the blue wire for - XO Vision XO-1400 Car DVD Player
Wiring scymatic for stero
1994 Mazda Protege Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Red
Car Radio Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Sep 07, 2012 | 1994 Mazda Protege
How do i correctly install the radio in a 2000 kia sephia
Here are the radio connector wiring colors and what they do.
2000 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Ignition Switched 12V+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Red/Black
Left Front Speaker Wire (+): Black/Yellow
Left Front Speaker Wire (-): Blue/Orange
Right Front Speaker Wire (+): Blue/Green
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Green/Red
Left Rear Speaker Wire (-): Green/Black
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Red/Blue
Jun 28, 2012 | 2000 Kia Sephia
1997 wiring diagram stereo ford festiva
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Illumination Wire: Blue/White
ir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Negative Wire (-): Blue/White
Car Audio Rear Speakers Location: Shock Towers
Jun 22, 2012 | Cars & Trucks
I have a 1991 ford festiva i changed my radio and now my shifter and my dash lits dont work are they wired in with the factery radio
Hi, the factory radio uses the illumination wire, but the aftermarket radio does not. You have to make sure that wire is taped off so it doesn't short the illumination circuit. Check your tail lights fuse. If it's blown, pull the head unit and disconnect/tape off the illumination wire (blue with a white stripe) from the factory harness. Then put in a fresh fuse. If you have more questions, please specify the model of the head unit.
1991 Ford Festiva Car Radio Wire Diagram
Nov 21, 2011 | Car Audio & Video
I need speaker wire color codes from in dash the colors i have are blue and white gray black tan green and black brown and green white and pink blue and pinik
This should be what you need
Constant 12v+ Wire: Green/Violet
Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green
Illumination Wire: Light Blue/Red
Antenna Trigger: Orange/Blue
Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Dec 26, 2010 | 1995 Ford Explorer
I need the audio wiring diagram for 1990 mazda B series
1990 Mazda B2000 B-Series Pickup Car Stereo Radio Wiring Diagram.
Car Radio Switched 12V+ Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Left Front Speaker Wire (+): Blue/Red
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (-): Blue/White
Rear Speakers Size: 4′
Rear Speakers Location: Rear Corners
Left Rear Speaker Wire (+): Blue/Red
Left Rear Speaker Wire (-): Blue/Green
Right Rear Speaker Wire (-): Blue/Green
pls rate
Aug 16, 2010 | 1990 Mazda B-Series
What colors of stereo wires go together from a pioneer DEH-P4200UB car stereo to a 1995 mazda 626
heres the wiring for your car radio Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 5′ x 7′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
and here is the link for your radio install http://www.pioneerusa.com/StaticFiles/Manuals/Car/DEH-P4200UB_InstallationManual1006.pdf
Aug 02, 2010 | Pioneer Car Audio & Video
I need the wiring diagram to install a Alpine 7516 in a Dodge Colt 1994.Thanks! Alain
1994 Dodge Colt Car Audio Wiring Guide
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Red/Black
Car Audio Front Speakers Size: 4′
Car Audio Rear Speakers Size: 6 1/2′
Left Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Positive Wire (+): Blue/Red
The manual for the Alpine 7516 can be purchased here:
https://www.samswebsite.com/en/photofact/search/index/model/7516
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Alpine Car Audio & Video
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Need to know factory wiring colors to hook up aftermarket stereo
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Ground Wire: N/A
Car Audio Rear Speakers Location: Side Shelves
Aug 03, 2008 | 1990 Mazda 626
XO Vision XO-1400 Car DVD Player Logo
16 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
