Question about LG 32LG30 32 in. LCD HDTV
My tv has NTSC system but our local transmission is pal system. so picture is black & white and has no audio
    New Friend:
  • 4 Answers
It seems you are going to have to buy a PAL to NTSC converter box, check out the following info i got from eHow.
NTSC, or National Television System Committee, is the system used to broadcast television that is still analog in North and South America and parts of Asia. PAL, or Phase Alternate Line, is one of the other two analog broadcast systems used in much of the rest of the world. If you are in an area that can pick up both, but your television is made to receive only one of them, you can buy an PAL-to-NTSC converter that will allow the correct input to your TV.
Purchase a PAL-NTSC converter. Most mid-range converters will convert back and forth between either system, so if you're not sure which system your television picks up, you can buy one of the dual converters. See the References section for an example of a mid-range converter. When you purchase, choose either 110V or 220V power source, and which country you are ordering from (you will need the appropriate power cord adapter for your country).
Plug the included connector cord from the "Input" (or possibly "Antennae") jack on the back of your television to the "Output" on the converter. Also, plug the power adapter into a floor jack or other power supply.
Move the Input switch to PAL and the Output switch to NTSC on the converter if it is a dual converter. This will enable you to receive PAL TV signals and convert them for your NTSC TV.
Read more: http://www.ehow.com/how_6281541_convert-pal-ntsc-tv.html#ixzz2tSt08zQt
Posted on Feb 16, 2014
4 Suggested Answers
SOURCE: NTSC to PAL
I am afraid this reply is too late, but if you happen to stop by the site: The set has a built-in NTSC tuner, with no PAL tuner, as it is advertised in the US. So the answer is: No, you can't do PAL.
But if your manual says it has the PAL tuner, then you should be able to find a switch on the set or a button on the remote to change over to PAL.
Posted on Jul 24, 2008
SOURCE: Multisys. TV NTSC tuner to PAL conversion, Brand LG,
i am using a mini multisystem modulator i fixed inside the tv.i used the s-video input of the tv to connect the output of modulator i.e AV -OUT.it works via remote sensor of d mdlt positioned at the IR of the tv.
Posted on Sep 08, 2010
SOURCE: LG 22" LCD Screen went white
same things happened to me...did you solve this?
Posted on Dec 21, 2010
Why does it only play dvds in black and white
check color system settings pal to pal
TV PAL then DVD player has to be PAL
TV NTSC then DVD player needs to be NTSC
If mismatch in settings you may experience black and white
Dec 31, 2014 | JVC TH-A30 System
Connecting Virginmedia TV settop box to PC using Philips TV capture card. Result - sound and picture BUT black & white!!
You are either running NTSC into a Pal system or the other way around. Check the setup menu on the Virginmedia box to make sure what it's running, then make sure the TV card is running in the same format.
Hope that helps =)
Apr 09, 2008 | Computers & Internet
How can i make my samsung LCD TV pictures change fro black and white to coloured in ghana
Set is likely formatted by design for North America which is set up for NTSC transmission system and likely there it is PAL--both issues fit this. You will need a PAL (if system there) to NTSC converter box.
Jun 13, 2012 | Samsung LN37A550P LCD TV
I have attached a DVD Player to my LG TV, using the appropriate cables. I have sound and a black & White picture. What have I done wrong please?
It is very simple, the mode of your DVD or TV is not correct. Check the NTSC/PAL setting's on your remote control for the DVD player. If your DVD player is on PAL system, then you TV should also be on PAL system. Likewise for the NTSC system, possible to put both on AUTO mode then do it. Don't get confused it is just a simple setting which you can do it without any problem, and in future you can do it for others.
Mar 04, 2011 | LG Televison & Video
I'm connected but only get audio and black and white. picture
pls change your video ntsc to pal or pal to ntsc as per your countries local vidieo transmission, this should work.
this is applicable for av connections as well
Jan 10, 2011 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Black and White on TV
europe uses PAL and not NTSC..change the setting on the TV or DVD player accordingly. Set the TV system to NTSC or the DVD system to PAL
Nov 09, 2007 | Audiovox D1708 Portable DVD Player
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
LG 32LG30 32 in. LCD HDTV Logo
113 people viewed this question
Computer Repairing
Computer Repairing
