Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
Need to find a schematic for the light switc and fan switch Something that tells me how to put the wires
2 Suggested Answers
SOURCE: Light Switch Schematic For Nutone Whispaire WA6500
No they shouldn't come apart. You need a new part. They are quite cheap - I have seen them anywhere from $4 to $15.
Posted on Feb 08, 2011
Cooling fan does not come on, need wiring
as you dont say what model/year vehicle it will go something like ....battery....wire....temperature switch....wire....relay....wire....fan....earth
Sep 01, 2014 | Cars & Trucks
How to tell when fan relay is bad
Need a test light and the wiring schematic. Should have power and ground to the relay. Also need a "trigger" wire which activates relay to allow power to flow out and to the fan.
Apr 05, 2014 | Scion xB Cars & Trucks
On light continually flashing when switced on fan not working
This is a programme mode but just can't put my finger on it this second. It isn't actually a fault. Try holding your finger on the on / off switch for 5 seconds.
Feb 10, 2014 | Miele DA 289-4 Kitchen Hood
Im taking out a switch in a four switch circuit
If you are planning to put 4 switches back in after the renovation, you need to make a wiring schematic of exactly how they are wired now and label each wire according to your schematic. Then when you put them back, everything will work. If you are going to use less light switches then the schematic will help with a smaller number of switches. These are 3-way switches, for your information, not regular 2-way switches!
Jan 02, 2013 | Dryers
We're wiring a 3 way fan switch. We have black (lead), green, gray and brown wires. We know where the black wire goes but were do the other ones go?
the wire from the switces usually correspond to the harness. the black is the feed (hot) green is ground or bare copper wire the gray is nuetral or white wire.the browns are switch wires,
Jun 12, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I want to connect up an extractor fan which is wired to the light switch and stays on for a time after the light switch has been turned off. There are 3 connections on the unit: 1 Neutral supply, 2...
wow that is a hand full,.
we dont know where you live (AC wiring varies but country)
usa is 120vac,60hz system and NEC , nema rules. and UL
nor the current wiring schematic not presented here.
nor the fan spec, name and model, so i can look it up.
what wires, the fan or the object you are wiring?
what fan?
what rack?
what wiring there now?
shop labor
i can do it for $25 alone
$50 watched by customer.
or tell you for $500
bind, we cant. even for a million,
Oct 18, 2017 | HP Extractor Fan Kit 110V Rack Mount Fan
Feb 10, 2010 | Broan-NuTone Intermediate Whispaire ...
Wiring diagram
1997 Saturn SL 1.9L MFI SOHC 4cyl
1991-98 Starting, Charging, Fuel Pump, Cooling Fan, and Headlight Schematics
1995-98 Stop Lamp and Turn Lamp Schematics
1991-98 Marker Light Schematics
1991-98 Back-up Light and Daytime Running Light Schematics
I hope help you with this. Good luck.
Sep 14, 2009 | 1997 Saturn SL
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
