How use lg 32ln350b tv in pal system
How can i use it in pal system
  • gsarfaraz68
    gsarfaraz68 Feb 16, 2014
    Hi gsarfaraz68 , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • 4 Answers
Your tv may be NTSC and not PAL. if thats the case then just get yourself a PAL to NTSC converter box and it will fix your issue.
Posted on Feb 16, 2014
I have rca flat screen trying to use LG blueray player connected but the picture is black and white what is wrong
what tv colour system are you using PAL or NTSC check each devices settings and see if they match up.
Dec 22, 2014 | LG Televison & Video
My tv has NTSC system but our local transmission is pal system. so picture is black & white and has no audio
hi,
It seems you are going to have to buy a PAL to NTSC converter box, check out the following info i got from eHow.
NTSC, or National Television System Committee, is the system used to broadcast television that is still analog in North and South America and parts of Asia. PAL, or Phase Alternate Line, is one of the other two analog broadcast systems used in much of the rest of the world. If you are in an area that can pick up both, but your television is made to receive only one of them, you can buy an PAL-to-NTSC converter that will allow the correct input to your TV.
Purchase a PAL-NTSC converter. Most mid-range converters will convert back and forth between either system, so if you're not sure which system your television picks up, you can buy one of the dual converters. See the References section for an example of a mid-range converter. When you purchase, choose either 110V or 220V power source, and which country you are ordering from (you will need the appropriate power cord adapter for your country).
Plug the included connector cord from the "Input" (or possibly "Antennae") jack on the back of your television to the "Output" on the converter. Also, plug the power adapter into a floor jack or other power supply.
Move the Input switch to PAL and the Output switch to NTSC on the converter if it is a dual converter. This will enable you to receive PAL TV signals and convert them for your NTSC TV.
Read more: http://www.ehow.com/how_6281541_convert-pal-ntsc-tv.html#ixzz2tSt08zQt
Feb 16, 2014 | LG 32LG30 32 in. LCD HDTV
Lg led tv
try changing area systems in main menu IE pal to something local to you.
May 13, 2013 | LG 42SL9000 42 in. HD-Ready LED TV
Will a LG LED TV model 42LV3500 bought in Canada work in India
I'm sorry to inform you that the TV is not directly compatible with the power and color system available in India. The TV is only designed to work with 120V/60 Hz and NTSC color System. The power specification in India is 230V/50Hz. The color system is PAL.
However, you can use a Voltage converter and PAL to NTSC converter to make use of the TV in India.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 05, 2011 | LG 42 42LV3500 42 LCD TV
I have attached a DVD Player to my LG TV, using the appropriate cables. I have sound and a black & White picture. What have I done wrong please?
It is very simple, the mode of your DVD or TV is not correct. Check the NTSC/PAL setting's on your remote control for the DVD player. If your DVD player is on PAL system, then you TV should also be on PAL system. Likewise for the NTSC system, possible to put both on AUTO mode then do it. Don't get confused it is just a simple setting which you can do it without any problem, and in future you can do it for others.
Mar 04, 2011 | LG Televison & Video
I have sony wega trinitron and a day back purchased a new LG DVD player but the picture is black and white.I tried the Setup to change the color from auto to PAL but the option color change is permanantly...
Hello
Your TV model has only NTSC system with it. No PAL or SECAM. It is not a mutisystem compactable one. Check whether your DVD has NTSC playback option. If it has, you can see discs writed in NTSC system through your TV. If it has not equipped with that system, it is useless for your TV. Sony KV32FS120 and KV36FS120 models are only meant of US standard, and have only NTSC system with it. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Multisys. TV NTSC tuner to PAL conversion, Brand LG,
Safakersaven: if you ever find the solution plase pst it here or email me, please. I have the exact same model LG and the same 4.50 soft. and the sme problem in converting to PAL Thank you.
frankfone@gmail.com
Dec 31, 2009 | LG 32LG30 32 in. LCD HDTV
TV with PAL Only DVD
No,tv is PAL or NTSC not possible to change region setting in tv.
Dec 12, 2009 | Televison & Video
LG RC700N GRAY ROLLING SCREEN ALL TIME AUDIO SOUNDS FINE
The player's video system is not compatible with the TV's video system. Check it's specifications and look for the video system. it's something like NTSC, NTSC-M, PAL and PAL-SECAM. Set the TV's video system to the player's video system or just simply set it to "AUTO" if available.
Aug 06, 2009 | LG RC700N
NTSC to PAL
I am afraid this reply is too late, but if you happen to stop by the site: The set has a built-in NTSC tuner, with no PAL tuner, as it is advertised in the US. So the answer is: No, you can't do PAL.
But if your manual says it has the PAL tuner, then you should be able to find a switch on the set or a button on the remote to change over to PAL.
Jan 09, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
