Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
Need to reconnect my stove hood,have two switch,s fan and light 3wires black,yellow&white need schamatic
2 Suggested Answers
mkh5094
  • 145 Answers
SOURCE: Would this work or burn
Yes everything would work perfectly. I see no problems in your plan. Even if both fans were run off of one switch they would not burn out, the circuit it appropriately sized. You could even go a step down to save yourself some money and use 14/2 and 14/3 (supposing its only the fans running on the circuit). You can run up to 16 amps on 12 AWG wire and up to 12 amps on 14 AWG wire (80% of breaker tolerance). Also when it get to the fans use a wire junction box run your 3 wire cable in there and branch out to your fans from there with separate 2 wire cables. I believe that was your plan just wanted to clarify. Good luck!!
Posted on Apr 28, 2010
Look the fuel pump is the gas tank of a 1996 ford
On most models the fuel pump wires are pink-black and black. The third wire is usually yellow and its for the gas gauge.
Sep 04, 2014 | Cars & Trucks
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
How yo wire up ceiling fan with light
Typically with only one switch controlling the fan/light the connections in the ceiling are white to white, black to black and blue. if you have a separate switch for the light and one for the fan, typically the wiring is white to white, black to black, red to blue.
Mar 07, 2010 | Dacor Remote Light Control for Ventilation...
The light is not working. Pulled the base off and
I would say the extra wires are for a receiver which must be in there somewhere.
To bypass the receiver, look for black, blue & white wires. Black is fan, blue is light fixture -- white is neutral.
The source wires (from the electric panel) would be black and white and bare copper (ground).
From here, you need to tell me what switching configuration you want: one wall switch, two wall switches, one wall switch w/ two pull chains, etc.
Charlie
Aug 17, 2009 | Hunter 20765 Stratford II Fan
Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Jun 30, 2009 | Dryers
I have a carrier AC model#50ee036330, the fan motor went out it was an emerson2 speed with 3wires.IMtrying to replace it with a GEMOTOR no.3586 with6 wires at 1 side and 4 on the other.6wires arered black...
jenny,White and black is high speed,wire nut the yellow and blue by themselves(2) brown wires cap.yellow brown together and orange and purple together they should be direction wires.If the fan runs backwards change them
Aug 14, 2008 | Carrier Heating & Cooling
Wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
64 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
