Question about Refrigerators
High-pitched chirp at same time every night
Every night, at 8:40pm our GE side-by-side fridge would make a high-pitched chirp. It would stop for a few minutes if we pulled it away from the wall or gave the fridge a small nudge. It did this through the entire night. Two repair men came and went without finding a solution (they never head the sound since it only happens at night). So, today we had a brand new Samsung side-by-side fridge delivered. 8:40pm arrived and so did the high-pitched chirp! Is it the water line going into the fridge? Help!
    Sergeant:
  • 319 Answers
High pitch noises are very difficult to isolate. Since you have replaced the refrigerator, I would look for something else in the immediate vicinity that might be generating the sound.
Posted on Feb 16, 2014
  • 27 Answers
SOURCE: Kenmore Fridge 4 yrs old side by side model not cooling
Hi. Your refrigerator is under 5 years and the compressor is still under full warranty. Call Sears and get it fixed parts and labor included. There should be no charge to you whatsoever. Make sure they understand that on the phone when you set up the appointment. You would be better off having a different technician from Sears come out to your house, as the one that came was not honest with you. Good luck, Mack
Posted on Jan 06, 2008
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
Posted on Apr 22, 2008
  • 531 Answers
SOURCE: High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Posted on Apr 13, 2009
Maytag317
  • 1136 Answers
SOURCE: Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 14, 2009
SOURCE: GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Posted on Feb 15, 2011
Why is it chirping?
My guess is you probably have a loose screw or nut that is allowing something to vibrate when the condenser is running. Check the front cover on the bottom of the fridge see if that is loose. Hope this helps.
Aug 29, 2015 | General Electric GSS22JET Side by Side...
My GE Side by Side is about 4 years old and it has made a high pitched howling noise for a year or two. Everyone who comes to visit notices it. I can hear it in the bedroom at night. When I turn the fridge...
There is something going on with the fan in the refrigerator. It may be blocked by ice or it is blowing across a crack just right. Take some time to inspect the passageway between the freezer and the refrigerator, and you should find something out of place. If you can't find anything, turn the whole thing off and completely thaw it. When you turn it back on, it should be better.
How long is your warranty good? You might be able to get it repaired for free.
Jan 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Ge side by side refridgerator
we had the same problem. called a repairman and they had to replace the electric unit - about $268. But I STiLL have that horrible high pitched noise every time the fan kicks in. About 20 minutes every hour. I have to leave the room. It kills my ears!
Sep 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE FRIG Model GSL25JFPJBS
my ge fridge has a hi pitch sound.
I hate it
Aug 14, 2008 | GE Refrigerators
Freezer fan noise
What you need is a new updated computer main board. Thay are fairly cheap and easy to install. My GE Side By Side did the same thing and the new motherboard worked like a charm. I think that this is the one you need but you can email the seller with your model number and he will tell you which one to get WR55X10552 GE Refrigerator Mother Board fits WR55X10335s.gif GOOD LUCK
Jan 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
Tv wont turn on
A high pitched chirp is a sign that you have a short on the load of your power supply. I just finished repairing one of these sets and it had a shorted horizontal output transistor and a bad flyback transformer.
Jan 10, 2007 | RCA F32444 32" TV
Refrigerators Logo
183 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
