Question about Adobe PageMaker Plus 6.5 for PC
Alt character codes list - Adobe PageMaker Plus 6.5 for PC
    Master:
  • 680 Answers
Do a search for character Map
Terry
Posted on Jul 15, 2014
How to get the sterling pound symbol in K120 logitech keyboard
Entering the following keystroke combination will result in the Pound Sterling sign being displayed:
While holding down the ALT key, enter 0163 (ALT+0163).
This is known ASCII Code. (Pronounced Ask-key.)
A complete list of all 256 character codes is available at http://www.ascii-code.com/ .
All manner of Latin-based characters are available. Check it out.
To use any ASCII Code, choose the "HTML Number" and substitute "ALT+0" for "&#".
In this case, the HTML Number is &#163, therefore when entering text, type ALT+0163 (NOTE: "ALT+" means "While holding down the ALT key, press and release each of the four digits in sequence, then release the ALT key.)
Hope this helps.
Sep 02, 2014 | Logitech K120 USB Keyboard
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
How do I find and then print off character list
Google Special ALT Characters and find Ted's HTML Tutorial. I printed off the list from there.
Aug 10, 2014 | Microsoft Windows 7 Ultimate for PC
Alt code 9791
Some software won't let you type those characters directly.
You can run "Character Map" to find the desired characters, type the codes into the "Characters to copy:" pane, click the Copy button, paste them to a line within your document, and copy/paste from that string as needed. The System character set has those characters.. they're not shown, but the Alt key combinations display the characters needed.
I was able to paste the character in this post, but I got the message "Please use English characters only" so I had to remove it before I could post.
Dec 08, 2013 | Computers & Internet
I am trying to get a list of the ALT & Ascii codes list so that I can make my measurements in my recipes all of the same. My computer will change 1/2 by using Alt0189 but I can't find other...
Open the "character map" program that comes with windows. It will tell you all of the alt codes.
For example:
Alt + 0188 = ¼
Alt + 0189 = ½
Alt + 0190 = ¾
Sep 08, 2011 | Computers & Internet
How do I get swedish letters on an asus keyboard?
You get special characters by using alt codes. That is, you press and hold the "alt" key while entering a 4-digit code using the numeric keypad (or, on a laptop, the keys that serve as a numeric keypad). When you release the alt key the special character appears at the cursor location. This page lists the characters and corresponding code.
If you are using an application like Microsoft Word, there may be an "insert special character" command available. Then you can pick the character from a table instead.
Mar 04, 2011 | Computers & Internet
I am Afrikaans speaking and my language needs the ^ and " on e's and o's. I can't find it on my new laptop
There's 2 ways (I'm assuming Windows):
1) In Start --> Programs --> Accessories.  There's a program in there called 'Character Map' that has all the accents and characters in.  Simply copy (CTRL + C) and paste (CTRL + V) the letters to where you need them.
2) If you have a numeric keypad on your laptop, turn on the NUM LOCK, and hold the ALT key down while pressing 3 numbers, and you get a character out.  On a UK keyboard, for example, ALT 155 is "¢" and ALT 156 is "£".  Which character you get out for a specific number depends upon which country you're in (the kb layouts are different), so I can't give you a list.  A little experimentation will enable you to find frequently-used ones.
Please rate me if you found this helpful.  Thanks.
Mar 06, 2010 | Toshiba 310CDT Keyboard
I just need to know how to use the diacritic/accent mark key on my Aspire 5610 keyboard.
I'll be glad to help you out with this. Assuming you have XP, you have 2 choices. Either use the Character Map, or an ALT code.
To access the character map, click
Start > All Programs > Accessories > System Tools > Character Map
An ALT code is simply when you hold down the ALT key and press a series of numbers on the keypad to get different symbols. Here's a list of ALT Codes:
http://tlt.its.psu.edu/suggestions/international/accents/codealt.html
Hope this helped :)
Nov 28, 2009 | Acer Aspire 5610-4648 Notebook
How do i make a character that looks like a 7 but vertical portion is straight
The answer is ALT + 191
To obtain an ALT Character:
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear
Found here... http://www.tedmontgomery.com/tutorial/altchrc.html
You will find all the special characters there.
Thanks,
John C.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
ALT Codes
I'm a little late to the game, but...
I share James's frustration. Seems like a dumb thing for Dell to economize on. Here's my workaround, for what it's worth.
  1. Open the Windows on-screen keyboard (osk.exe). And, for later ease of use, pin it to your taskbar. (Detailed instructions: click on the Windows start button, type osk.exe in the search box, right-click on the program, select Pin to Taskbar.)
  2. On the virtual keyboard, open Options and select "Turn on the numeric keypad." After saving the setting, press the NumLock button.
  3. Here's the tricky bit: press and hold Alt on your physical keyboard, and then press and hold Fn, again on your physical keyboard. You're holding them both down, right? Keep doing it. Now enter your four-digit code on the virtual (on-screen) keyboard. Release the physical keys. You should have your special character.
Hope it works for you.
Jan 21, 2009 | Dell Inspiron Mini 9 Notebook
Adobe PageMaker Plus 6.5 for PC Logo
59 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
