Question about Nordic Track NordicTrack A2750 PRO Treadmill
The belt will not centre at the front
The Belt will centre at the back, but will not at the front. Is there a front roller adjustment? The belt is now rubbing the full length on the right side.
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
2manyhobbies
  • 128 Answers
SOURCE: i have the Incline Trainer X7i. i lost the
Find the allen key that came with the treadmill. It is used to assemble and adjust the treadmill.
Locate the 2 adjustment screws at the rear of the machine. If the belt is shifting to the left, tighten the left screw (turn clockwise) and the same if the belt goes to the right, tighten the right.
Only turn the screw 1/2 turn and move the belt manually to shift the belt. If it requires more, turn another 1/4 turn, very little adjustment may be required to straighten the belt. Once the belt stops rubbing, start the machine running slowly (1-2 mph) and observe the belt FROM DIRECTLY BEHIND THE MACHINE. Carefully adjust the rear roller till the belt is as close to center as possible making small adjustments, 1/8-1/4 turn clockwise of the adjustment screws.
Posted on Dec 15, 2010
  • 95 Answers
SOURCE: Nordictrack C2050, belt was slipping and I got the
I am not an expert on what you may need to order but I do want to give you a link in case that may be helpful... FitnessRepairParts.com has parts lists for several versions of the C2050... look for a decal or label on the machine to get the exact model number, then click on that model and look in the list for 'Roller, Front' or 'Roller, Rear' or 'Treadbelt.' Hope that helps.
Also if you need someone to come look at it you can find a list of servicers near you here
Posted on Feb 17, 2011
  • 146 Answers
SOURCE: The walking belt on my
if it is moving to the right you must tighten the right side of the rear roller
you are doing wrong side
Posted on Mar 29, 2011
Pathmaster 8.0 treamill model 21-3688a fix
Drive Belt Installation for Treadmills
The drive belt is used by the motor to drive the treadmill walking belt via the front roller pulley. A drive pulley is mounted on the roller and the roller has knurling or a sleeve to help it drive the walking belt. The treadmill console detects the current speed of the treadmill by monitoring the movement of a magnet mounted on the front roller pulley with a reed switch or by using an optic switch which monitors an optic disk mounted either on the front roller or on the motor shaft. If the sleeve moves to the side, you will not be able to keep the belt centered and many optic disks can be warped if pushed to the side by the sleeve if it moves, but we do have replacement sleeve kits if needed.
Steps to Replace Drive Belt-
1) Remove the safety key and unplug the treadmill from the wall outlet.
2) Remove the screws securing the motor hood and gently remove the motor hood.
3) Using an Allen wrench provided with the treadmill, loosen the two rear roller adjustment bolts until the rear roller comes into contact with the walking board. Turn the bolts and equal number of turns on each side and keep a count of how many turns you made so you will know how to properly re-tension the walking belt.
4) Remove the drive belt from the motor pulley. Place a screwdriver between the pulley and the belt and turn the pulley by hand. Use the screwdriver to guide the belt over the edge of the pulley. Be careful with the screwdriver to prevent damage to the pulley.
6) Mark the position of the front roller axle on the front roller bracket above the front roller adjustment bolt using a Sharpie marker so you will know where to put the bolt back into position. Remove the front roller adjustment bolt if your treadmill's front roller has a pitch adjustment bolt. If your treadmill does not have exposed roller bolts you will need additional instructions. Please see the troubleshooting section on our website for further help.
7) Gently slide the front roller from out of its mounting position on the frame. Do NOT remove the roller from the walking belt.
8) Slip the old drive belt off the roller and loop the new drive belt onto the front roller pulley.
9) Replace the roller back into its slot on the pulley side and re-tension the front roller pitch bolt to its proper place using the Sharpie mark as a guide.
10) Using the screwdriver, loop the drive belt over the motor pulley. Many Icon units originally had the drive belt misaligned by design (if you can believe it). This was to use the side load of the drive belt in order to keep tension lower. It does lower amp draw for the machine and replacing a side load drive belt occasionally is much cheaper than replacing a motor and/or controller so if your original drive belt was off-centered, install the new belt in the same manner.
11) Re-tension the walking belt.
12) Plug in the machine and check the drive belt for slipping. You can use some automotive fan belt dressing on the grooved or contact side of the belt to help it with grip on the pulleys and it will treat the belt as well. We prefer using belt dressing rather than over-tensioning the belt for the aforementioned amp reasons as well as additional stress placed on the drive system parts.
13) Replace the motor cover and test.
14) Make sure the walking belt is not slipping and is properly aligned and your treadmill is ready to use.
Copyright 2009 by TreadmillDoctor.com, Inc.
All illustrations, photographs, and scanned images, and text are the property of TreadmillDoctor.com, Inc. and may not be reused, retransmitted, copied, given, sold, or bartered to any third party. The recipient of this property is authorized to use it only in the manner expressly indicated by a staff member of TreadmillDoctor.com, Inc. All rights reserved.
Jul 09, 2012 | Exercise & Fitness
I have a Black & Decker sander, model # 7447 and am having problems changing the sand paper.
The 7447 does not have a release lever. To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Jun 13, 2011 | Black & Decker Garden
Belt stops running although you can hear motor running. How do you replace front roller pulley?
Loosen off the rear roller adjustment bolts, 10 turns each side counterclockwise.
Remove the motor drive belt.
The front roller should now be removable. If you have difficulties, back off the rear roller adjustment bolts 3-4 turns further. Keep track of how many counterclockwise turns so you are able to readjust the belt after replacing the front roller pulley assembly.
Repeat the instructions in reverse once the front roller is in position.
Dec 16, 2010 | Epic View 550 Treadmill
How do I change the sanding belt on my 7447 belt sander
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
Belt skips
take the cover off, if the front drive roller continues to turn when the running belt stops, tension the running belt by using the rear adjustment screws. One full turn on each side should do it. If the front roller stops turning but the motor doesn't, tension the drive belt by adjusting the motor back.
May 26, 2010 | Proform 760 CrossTrainer Treadmill
C2200 belt is slipping How to adjust??
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s)
May 18, 2010 | Nordic Track /proform Treadmill...
When weight is put on belt it stops. works fine by itself at all speeds
If you can stop the belt. You need to be aware that both running & drive belts can cause the same problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | Proform Sport 1000 Folding Treadmill...
How can you tighten the walking belt on a Image 15.R treadmill. Im pretty sure that its the belt you walk on that is slipping and not the one under the hood but I could be wrong. Any advice?
If you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | RTO Image 15.0R Treadmill Walking Belt
Belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Feb 20, 2010 | Proform CrossTrainer Treadmill
Belt in Norditrack C2000, seems to be slipping when I run, I tried centering, did not solve the problem. I get kind of resistance. Do I need to change belt? what should I do
Most likely it is the Drive belt from the motor to the front roller, remove the motor hood, get it going at 3.0 mph and hold on to the rails, then put your foot forward and down pretty hard and see if it slips on the motor pulley, if so it's time for a new drive belt or an adjustment to it.
Jul 04, 2009 | Sportsart 6200 Treadmill
Nordic Track NordicTrack A2750 PRO Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
