Question about Fuji FinePix A340 Digital Camera
Canon sx170 is lens shutter not opening
Shutter on lens not opening
How do i replace lense cover on a canon sx170 is?
Since I cannot see your pieces, I can recommend actual replacement. You can Google your camera's make/model with replace lens cover and pick from the listings. You can also go straight to Canon USA and search their store as they have replacement lens covers. I did this here for another customer as an example.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
Jul 19, 2014 | Canon PowerShot SX170 IS 16 Megapixel...
Shutter isn't opening in the lens....
The SHUTTER IS NOT IN THE LENS. I\The shutter is in the camera body in front of the ccd or cmos sensor. You are talking aboput the aperture blades. Try changing the aperture, of course, unless you have a depth of field preview, you will not see the diaphragm open.close.
Jan 29, 2011 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Hello i have a problem with my canon powershot A1000Is digital camera. When i open the cam it only shows black screen and when i`m trying to take a picture is also black even if i check it on the computer...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 20, 2010 | Canon Powershot A1000IS Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Its shutter is not opening
Dec 18, 2009 | Canon Cameras
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
CCD problem and then lens problem
If the symptoms are similar as it was ccd imager problem then contact again with Canon for again free replacement of ccd imager chip in camera.
Can you post an image here that shows purple problem?
And if its lens problem as said by Canon then new camera would be better option instead of spending on its repair.
Thanks.
Sep 20, 2009 | Canon PowerShot A95 Digital Camera
I have the canon sx100 is, it dropped and now the shutter eye won't open
If only the shutter eye is not opening but the lens is extending properly, then you will need to remove the fron shutter frame and review it.
It may be that one (or both) springs that open the lens protector are loose, or the plastic tab that allows to open/close the lens protector is broken.
If the lens does not extend when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jul 18, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Canon powershot s2 15 shutter won't open
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
Fuji FinePix A340 Digital Camera Logo
57 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
