Question about Viper 4204V 2-Way 2,000-Ft. Remote Start System
Car stuck in park
Best buy installed product but the next day I could not get car out of park. I think it is stuck in valet mode or something
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
The parking lock solenoid is not working because the brake switch is wired incorrectly or bad or the fuse is blown. Or the part is bad.
Posted on Feb 17, 2014
Car starter in valet mode
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
Dec 07, 2013 | Dodge Cars & Trucks
Need to program rpn471t but I don't have a valet button in the car
Hello Lacey,
The only way to program an additionally remote on one of there systems is with a valet button. I would recomend that you contact a local install shop like Best Buy that works with DEI products. They likley will be able to program the remote for you.
Oct 27, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How do I disable the stock alarm on my 2001 Oldsmobile Aurora 4.0
Maybe you are in valet mode. This will drain your battery.
Nov 04, 2012 | 2001 Oldsmobile Aurora 4.0
After driving car for one houe, making two stops, shutting off engine and starting it up again (no problems), returning home, parking car and shutting off engine. Went back to start car less than 5 min....
You say it started up no problems? Then it wouldn't start? What did it do when it wouldn't start? Did it turn over, did it do nothing/something?
From just what little info I have I tend to think it's a starter. It starts fine when it's cold but after the engine heats the starter to engine operating temperature the starter maybe starts to drag? not allowing it spin the engine fast enough to start it???
This is only a guess with the limited info. Hope this helped thanks, HAVE A SAFE AND PRODUCTIVE DAY!
Apr 12, 2011 | Chrysler Concorde Cars & Trucks
Blue led stays on instead of blinking .
disarm system get inside the car turn key to ON position with door OPEN push the black valet button one time turn key off
now your out of Valet mode
or
open your door hit ARM then DISARM then ARM and that should also remove Valet mode if you don't know where the valet button is at.
May 14, 2010 | Viper Security and Remote Start System...
1996 Oldsmobile Aurora Electrical problem.
OK it sounds like you have an aftermarket alarm inside this vehicle and no remotes or siren (It was likely in the valet mode and you may have never known there was one ... as the dealerships tend to do so that they won't have to warrantee them) I would say that is why the lights are flashing and it won't start ... If I'm correct .... remove it ...
May 09, 2009 | 1996 Oldsmobile Aurora
Can't locate Valet switch
Does the vehicle have an aftermarket alarm system? Is the valet switch for this what you are looking for? If so, it depends entirely on who installed it as where they have put it, although it's usually under the dash on the drivers side. Some alarms have different sequences that you have to go through to put the alarm into valet mode, it's not usually just a switch that you flick. Best to pop into an alarm or stereo installer and see if they can spot it for you, or if the car is immobilised, find out what sort of alarm it is and call an installer for the info on the valet procedure.
Hopefully i haven't just wasted my time and yours, but i can't think of any other type of valet switch, and your description was pretty minimal. Cheers, Mark.
Dec 03, 2008 | Honda Accord Cars & Trucks
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
Oct 15, 2007 | Viper RCVGC022 Remote Control
Viper 4204V 2-Way 2,000-Ft. Remote Start System Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
