While doing nothing the screen will start to roll and will not stop or if it does it is on something different
SOURCE: Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
SOURCE: Dell Desktop, wont power up..monitor goes blank
Remove the cable. Keep pressing F8 while you power on the system and choose safe mode, press enter. Screen will roll up a few pages and stops for a while. wait a few minutes. windows will start in safe mode Scan for viruses. Restart. It is a virus problem
SOURCE: Laptop goes into permanent sleep mode, etc
If you can restart it and it starts up fine, then I would go into the power settings and disable sleep mode. Every computer is different on how to wake a sleeping computer, so you could read through your manuals and find out for yours, but I just disable sleep mode on all computers so i dont have to hassle with it.
SOURCE: CAN'T START UP COMPUTER DETECTS NO MOUSE OR KEYBOARD
The Blue Screen Your Are Talking About Its UNMOUNTABLE BOOT VOLUME and in case of blue screen mouse and keyboard are not detected as WINDOWS are not loading....
There Are 3 Ways To Resolve It But For All 3 Methods We Need The MICROSOFT WINDOWS XP OPERATING SYSTEM DISK...
1st Method Is WINDOWS RE-INSTALLATION. But In This Case All Your Data Would Be Gone..
2nd Method Is WINDOWS PARALLEL RE-INSTALLATION and in this method your data would be saved but you need to install the DRIVER'S SOFTWARE'S and other APPLICATIONS.
3rd Method Is The Easiest And I Prefer Which Is To Repair The Booting Sector.
To repair the volume, follow these steps: (10-15 Minutes)
Some things that you should know before you try this solution
loadTOCNode(4, 'resolution');
Note If no administrator password exists, press ENTER.
To repair the volume, follow these steps: 40-45 Minutes Complete File Repair
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Rate This Sollution Accordingly.........
SOURCE: dell inspiron 531 vista won't boot
try to hit win at keyboard, or ctrl+alt+del, if not working try safe mode(F8) and select recovery
