Question about Tappan Dishwashers
Water won't pump into tub, but will run full cycle. Dishes never washed. Soap powder still in bottom of tub. Water pumps out, but do not know where it is coming from. We are two seniors and don't use it every day.
VOTIT
  • 2071 Answers
SOURCE: Subject is Bosch dishwasher SHU6800.
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Posted on Aug 17, 2008
SOURCE: Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Posted on Nov 25, 2008
  • 61 Answers
SOURCE: Dishwasher fills, when the pump is supposed to start it just whir
Hello, sounds like a broken wash impeller or a stripped drive impeller (the piece that fits inside the impeller). These two parts are driven by the wash motor and propell the water through the spray arms. good luck
Posted on Dec 27, 2008
  • 338 Answers
SOURCE: GE Triton Motor comes on but no water comes out
clean out the filter in the floor in the back.
Posted on Jan 11, 2009
heatman101
  • 43501 Answers
SOURCE: soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 30, 2010
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
My dishwasher is not cleaning the dishes as well as it used to. Are there some simple things I can try before calling a tech?
Use a good quality powder detergent.
Check your incoming water temperature, 120 degrees plus.
Use a rinse aid such as Jet Dry.
Start the DW without soap and no dishes.
Once it starts the wash cycle pour in 1 quart of WHITE vinegar and let it finish the full wash cycle.
Then load up with dishes and powder detergent and run a load.
Jan 13, 2011 | KitchenAid Dishwashers
The detergent packet doesn't dissolve. The dishwasher seems to go through the cycles ... the dishes are wet. However I find the detergent packet in the bottom of the dishwasher.
Hello- Water flow, temperature, and pressure inside determine whether this little packet will dissolve.  Sump blockages or pump /motor weakness both effect amount water spraying inside. Some of these packets don't dissolve in time to enter wash water. Start by using powder or gel again. If it still leaves soap residue, other pump/motor issues exist. Let me know if this info helps- have more if needed. Thanks- ED
Mar 09, 2010 | Frigidaire Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dust on dishes after "clean" and spotted
The problem sounds like a hard water situation....Do you have hard water?...does your coffee pot take a long time to make coffee (an older coffee pot) if so you may consider a small water softener attached to the water inlet line or a water filtration device...as hard water will do just that..leave spots on the glasses and silverware as well as colored dishes, that look like little circles of whitish dried chemical or powder stains. Yes you can run a full bottle of vinegar in your dishwasher but monitor the cycle closely so it does not go into the drain cycle right away...and let it run through an extended wash cycle 2-3 times....before it drains so as to be able to maximize the effect...and as the aforementioned suggestion states you can also run some CLR through the system...BUT be CERTAIN to run it through several wash and rinse cycles after doing so as the chemicals in CLR are not healthy...and do not leave any dishes in as you do so (whereas vinegar is just Acetic acid and organically based). Also it is impossible for any concrete to have gotten into the dishwasher from anything poured down the kitchen sink drain since there is a valve in the drain pump called a "backflow preventer" that prohibits anything from entering the dishwasher. Also you may want to take out all the trays and remove the screem in the bottom of the dishwasher that covers the engine and pump assembly where the sprayer arm sits atop of. After doing so ( three -6 screws) clean anyfood or residue found ther out with a shop vac or something and reassemble.
I hope this helps....if so please let me know by rating me ...thank you....The Fang
Mar 24, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
ASKO MODEL 1996 WILL NOT WASH DISHES
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
Mar 14, 2009 | Asko 1996FI Dishwasher
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishwashers Logo
13 people viewed this question
Top Tappan Dishwashers Experts
marley mcelhinney
Ronald Rissel
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
