Question about Dynex Computers & Internet
Technika 4 port usb hub
Usb will not install correctly, device discriptor failed
alocenar
  • 293 Answers
SOURCE: Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Posted on Mar 25, 2007
  • 397 Answers
SOURCE: USB hub
Do you have Windows XP and at least Service pack 2 installed.
Service Pack 2 comes bundled with the neccessary drivers for USB 2.0
In device manager under the USB heading you must have:
PCI to USB Enhanced Host Controller
In the list.
Posted on Jul 22, 2008
mediarich
  • 188 Answers
SOURCE: t40p usb 2.0 ports acting like usb 1.0
There is no hardware or software fix for this. Here is a thread on what might be your problem. http://forum.thinkpads.com/viewtopic.php?t=67571
Posted on Sep 25, 2008
Geekman
  • 32281 Answers
SOURCE: Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
Posted on May 05, 2009
anandg27
  • 1272 Answers
SOURCE: 4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Posted on Jun 23, 2009
Connectland usb u2mnhub not connecting any devices
Go on line search manufacture if your hub and check for laters drivers and then delete and reinstall software or just new drivers, also check by going to start menu look for control panel look for device manager select it , then scroll down list till you see USB devices , look at usb icon host controllers and see if there's is a failed icon symbol beside your USB icon like a red or yellow exclamation mark or an x
Dec 15, 2012 | ConnectLand CLU2FPHUB4W USB 20 4 Ports Hub...
My USB ports won't work on my gigabyte MA69VM-S2 mobo with win7
Unlikely to be issues with the OS. Have you recently upgraded to Win 7 from Vista or XP? and did the USB ports work with this OS?
Do ALL usb ports fail or is it just one or two and are these the front USB's or rear USBs?
Dec 29, 2010 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
I installed a 4 port hub to speed up my file tranfer to a flash drive. The files transfer but not any faster then using the front usb ports. It is normal?
Yes. While the speed from the USB device to the USB hub may be faster (USB 2.0 protocol, rather than the slower USB 1.1 protocol), your hub is still connected to a USB 1.1 port on your computer.
Aug 22, 2010 | Belkin ExpressBus (F5U021) 4-Port USB Hub
I purchased a 4 port usb 2.0 hub can't seem to work
Have you install the driver first before connecting it? Check out the Device manager entries if showing any yellow mark?
Goto start --> Run --> type in there --> devmgmt.msc this will open up the Device manager.
Check it and let me know. Have a nice day
Mar 17, 2009 | Cable Showcase 4-Port Mini USB 2.0 Hub, AC...
USB Port has failed; 4E00:032B
Electrical surge on hub port. Either a device attached to the port, or the port itself, has drawn more current than allowed, and the hub turned off the port. The port will not function correctly until you reset it. If the device is the cause, it must be detached before resetting the port. To reset the port, disconnect the device, and then click Reset in the dialog box. If the port is the cause, close the dialog box, and do the following to re-enable the port:
Disconnect the hub.
Re-attach the hub.
If it is the root hub, unplug all attached USB devices from the computer, and (if they have power supplies) unplug them from the electric supply. After a few moments, reconnect the devices. The computer can be restarted at any time.-->
Dec 22, 2008 | Dell Inspiron B130 Notebook
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
Hi there I just brought a mikomi gp-311a 4 port usb hub for my aspire 5315 laptop (1gb). After root hub installed sucessfully,i added my other usb devices into the hub and it is not regonising any of my...
The problem is that some usb hub devices are not powered enough to recognise peripherals, i always recommend buying a mains powered usb hub as the pc's supply can find it difficult to power the usb ports enough as well as powering other components in your pc.
Sep 12, 2008 | Computers & Internet
Installing USB Hub
After installing the USB controller card into a PCI slot inside your computer, connect the 4 port hub to it with the supplied cable. (at the back of the computer)
Do not connect the DVD Recorder to the old usb ports. They will still work, but obviously not 2.0.
Connecting the power supply for the hub is optional, but usually a good idea.
If your computer still doesn't recognize the hub, make sure you have all of the latest windows updates and try running Add New Hardware in control panel. Also, just unplugging the hub and plugging it back in will sometimes work. Use a different port on the controller card if necessary.
As a last resort, you may need to disable the onboard usb controller through your system bios.
Good Luck
Sep 11, 2008 | CyberPower CPH420P 4-Port USB Hub
USB hub
In the list.
Jul 12, 2008 | Micro Innovations (USB204N) 4-Port
When I plug a device into the hub, I can't locate it.
for usb hubs some of the port could fail any time so test all the ports to identify which one is working
Mar 02, 2008 | GE JASCO (HO97878) 4-Port USB Hub
Computers & Internet Logo
64 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
