Question about 1988 Chevy S10 Pickup Truck Chrome and Silver Grill
1998 Chevy s10 pickup truck having trouble keeping it running
I replace the fuel pump in other field components on my chevy S 10 1988 pickup truck I'm having trouble getting to start keeping it running what could be the cause of this
  • Jeff Youtsey
    Jeff Youtsey Feb 17, 2014
    Also mark i know i had a pluged fuel filter on my 89.Its a dood thing to replace this about every other oil change . Due to condisation in the tank that seems to stay in the filter because they are in the frame rail. good luck. peace
  • Fernando Segovia Jun 01, 2014
    How's your MAP sensor? This sensor monitors your air filter. Lets the computer know if the air filter needs replacing. Find the MAP sensor wire connector and disconnect it from the MAP sensor (this by-passes the MAP sensor), then turn the engine on to see if this corrected the problem. If it did; you have a bad MAP sensor.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 104 Answers
Weak fuel pump? clogged injectors! vacuum leaks.
Posted on Feb 16, 2014
Testimonial: "Thank you for all your help I appreciate it I'll look into this"
2 Suggested Answers
lecomptesylv
  • 7 Answers
SOURCE: 1994 Chevy S10 Pickup v6 4.3L bogs down in any of the forward gears but runs good in Park, Neutral and Reverse.
check your spider webb on top of your intake its a piece that shall cost u about 100.$
Posted on Nov 16, 2013
What would cause you to lose fuel pressure while driving.
Chevrolet S-10 Questions - Fuel System Loses Pressure ...
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusJul 28, 2012 - Fuel System Loses Pressure - I have a 2003 Chevy S-10 Pick Up with the 4 ... car a few times, what essentially you are doing is priming the fuel pressure. ... A dirty fuel filter will not cause the lines to lose pressure after the engine is shut off. ... I have a 98 s10 2.2 liter and it was driving fine all day then when ...
Chevrolet S-10 Questions - My 2001 S10 has a hard starting ...
CarGurusSep 16, 2012 - My 2001 S10 has a hard starting problem if the truck sits between 1 ... Vacuum leak, have you checked fuel pressure while it sits? ... Would the spider alsocause a misfire at low rpms? .... at an idle, or squeaking while driving and it gets faster as you go? ..... 1994 Chevrolet S-10 2 Dr STD Standard Cab LB.
Chevy S-10 Won't Start - Repalced Fuel Pump and Pressure ...
www.cartruckinfo.com/chevy-s10-wont-start.html
Chevrolet S-10 pickup won't run and has no fire unless I jumper the fuel pump relay. ... Once the truck starts and is running you can remove the jumper to the fuel pump ... Iwould get the fuel pressure checked to start with, because that's where the ... 93 gmc 4.3l FI runs but dies out loss of power after 5 mins of running then ...
Stalling S10: I Have a 1994 Chevy S10 2.2l It Stalls After 35 ...
Dec 10, 2015 | 1994 Chevrolet S-10
Having problems with chevy s10 replaced fuel pump
Check the cable that goes from your battery to the fuse box the relay that is clicking is on. Check for lose bolts or corrosion of the contacts or something like that. If the relay is clicking it sounds to me like it is a voltage issue going to the relay.
Oct 05, 2009 | 1998 Chevrolet S-10 Pickup
1998 chevy s10 won't start, engine cranks but it won't turn over.
replaced your fuel pump and when you buy it make sure to replace the oil sending sensor on the fuel pump it comes with a replacement when you purchase a new fuel pump
Jun 07, 2009 | 1998 Chevrolet S-10 Pickup
Car starts dont run
Go to autozone, there you can rent their tool to check the pressure of your FPR. Then you should be able to connect that tool to your cars fuel line. Which will tell you the pressure.
This could and very well may be your fuel pump. Fuel pressure regulators dont go out too often.
May 30, 2009 | 1998 Chevrolet S-10 Pickup
Where is the oil sending unit located on a Chevy S10 Pickup.
MY S-10 IS LEAKING OIL. I WANT TO KNOW WHERE THE OIL SENDING UNIT IS.
May 29, 2009 | 1998 Chevrolet S-10 Pickup
1988 Chevy S10 Pickup Truck Chrome and Silver Grill Logo
260 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
