Question about Samsung FP-T5884 58 in. Plasma Television
Intermitent burning smell.
Recently have sensed burning smell. First time last week thought it was something else. Second time pinned it down to the TV. No smoke. TV continued to work fine. Was strong, had to vent entire house and smell still came came out after turning TV off. After some internet DIY education today I took the back off and dusted the thing. No obvious signs like bulging capacitors or burned components. Cautiously watched TV today with back off, from time to time smelling and watching to see which board is the culprit. TV worked fine and may have to keep on doing that for a while. Did notice a green light blinking in the back. Don't want to call a technician until the problem is narrowed, otherwise could end up repairing the wrong board, costing more than a new TV. BTW, in addition to the two burning smell events, continuously the TV is giving off a nasty chemical emission. Can't really smell it, but I can taste it. However impossible to pin down as taste buds aren't that quick and it takes a while for the sourness to be felt. Actually feels like the milder version of the burning smell. I guess I could let the TV on for many hours until it gathers enough heat that in the afternoon the event might repreat to determine the cause. Appreciate advise.
  • 1476 Answers
SOURCE: SCD 6040 Dead
I would not know why the service center would not tell you the truth but no matter what the problem is my guess is they charge a flat rate so whether it is an active component (IC) or passive (capacitor/resistor) the cost would be the same. Really, the parts are not what the cost is about, it is the labor, etc. It sounds like you have nothing to lose by looking at it yourself. If you have jewelers screwdrivers, magnifying glasses, a steady hand and lots of patience remove the case to get access to the battery input area/board. With your background in EE and a DMM you should be able to determine which part smoked. It may be as easy as just looking at the board. I say give it a go. You have nothing to lose as you can always put it back together and have them fix it later if you can't. Or you can just let it go and buy a new one. If you can determine which part it is you may be able to replace it also. I do not know your soldering capabilities. Either way you'll know what the real problem is and it won't cost you $150.00. Good luck.
Posted on Jul 25, 2006
SOURCE: Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Posted on Sep 23, 2009
  • 15 Answers
SOURCE: Moving objects extremely blurry in SAMSUNG LCD-football, golf,etc
This is a problem that will pretty much just be there on this TV. I know it has an awesome long as nothing moves. You can try putting it in "Game Mode" in the user menu and that usually takes care of it but you didn't buy the 120/240 Hz tv to watch it in 60Hz. I would say exchange it, and in my opinion buy a good plasma :)
Posted on Feb 24, 2010
  • 4889 Answers
SOURCE: Samsung LN46A550 LCD power on/off problem again.
It is the Main A/V board that is faulty, not the power supply. The rainbow screen that you are seeing and the searching for signal message before it shuts off confirms this. It is the large board at the center of the tv. If you can get me the part number off it, I can find you the replacement. It will be either printed on the board itself or on a small label.
Posted on Feb 05, 2011
  • 11361 Answers
SOURCE: TV WONT SWITCH ON LE26A456C2D standby light blinks
Please read my giude then you may understand more as to what it takes to make the TV functions.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Mar 06, 2011
Burning rubber smell when slowing down in an 89 Ford Bronco XLT?
Check under the car and look for a plastic bag that may have melted on the exhaust.
Feb 20, 2014 | Ford Bronco Cars & Trucks
I have a 2004 Chevy blazer V6. The last few mornings I have had a lot of trouble starting it , almost like it's flooded. You can smell gas. After you get it going it is kind of jerky but after...
Sounds like a faulty fuel pressure regulator.Pull the vacuum line off the fuel pressure regulator.If fuel runs out of it replace the regulator.
Jul 12, 2011 | 2004 Chevrolet Blazer
Amana ALW880QAW doesn't spin and agitation is slow
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
I bought my 1999 Lincoln Continental as a second vehicle. Drove it home with no apparent issues. The man I bought it from told me that an O ring needed to be replaced on the transmission pan and had a slow...
Whinning noise is the bearing of the oil pump inside torque converter.
Burning smell fluid has little to know pressure ( cause pump is dying) can't circulate to cool parts as well as provide pressure. Time for a rebuild.
May 17, 2010 | 1997 Lincoln Continental
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Intermitent gas smell
yes it is possible. a faint smell now and again from a gas stove is normal, as it has many burners to and oven. if smell is not constant, nothing to worry about.
Sep 09, 2009 | Kitchen Ranges
Samsung FP-T5884 58 in. Plasma Television Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
