Question about LG 52LG70 52 in. LCD HDTV
Lg Won't turn on with remote
Mic won't work at auxiliary mode
On the remote control, there is a blue "Magic Mic" button. Press on that your mic will turn on in any mode.
Just joking but I've been mad about how bad this LG home theater system is. It can only play extremely limited video files and turn off the mic in AUX mode. So the answer is you really can't do that. Buy a mixer instead.
Jan 19, 2013 | LG Audio Players & Recorders
My lg remote won't work
The remote itself can be tested by almost any TV shop to see if working or not---pointed at a tester and any or all buttons pushed to see if remote is working or not.
Many digital cameras will in a very dark room react in same way with a faint flash on the camera display when buttons are pressed.
If remote tests good the set does have a remote receiver built into the front of it, that would be suspect if the remote checks good.
Oct 15, 2012 | LG Mkj40653801 Factory Original Remote...
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
Won't turn n screen
If you have power light on turn on by the remote.Also change batterys in remote
Aug 17, 2012 | LG Televison & Video
Why won't any universal remotes work with my LG tv?
The two possible reasons are:
1. None of the codes are correct for this model.
2. The remote infrared receiver in the set is bad.
(maybe the reason the other person got rid of the set?)
There are some ways around this depending on how you hook up and what you have for signal:
If a box (cable or sat) is connected to one of the sets of audio/video jacks on the set--switch to that input and change channels etc with the box!
Use the box remote for functions like channel and sound etc.
May 01, 2012 | LG 26LG30 26 in. LCD TV
Lg 42pg20 remote won't work how to program
Hello
Buy a univesal remote control, which have setup codes for LG tV. You can get this information from the catelogue accompanied with the remote control. There will be proceedings also to setup the remot to tV. Or get its orginal remote control from the authorised service center for LG at your town.
Feb 27, 2012 | LG 42PG20 42 in. Plasma HDTV
I am trying to add my lg tv device to my Panasonic DVD player remote, but I can not find the code for the lg tv. The model of the tv is 32LC2D.
Hello...Here are some remote codes to try...0004, 0005, 0050, 0009, 0227, 0338, 0012, 0057, 0080, 0156...Hopefully..you won't have to go thru them all before you find one that works....I hope that this was helpful....PEACE...
Jan 25, 2012 | LG Televison & Video
LG 52LG70 52 in. LCD HDTV Logo
23 people viewed this question
Computer Repairing
Computer Repairing
