Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
A
Anonymous Posted on Feb 16, 2014
Ctronic oven control does'nt function on Whirlpool RF388LXG/QZ
Can turn on a burner and control flashes but doesn't heat element or turn on oven
5 Related Answers
Anonymous
  • 33 Answers
  • Posted on Dec 17, 2008
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Anonymous
    • 14 Answers
    • Posted on Feb 14, 2009
    SOURCE: Electric Dbl Wall Oven-loud popping noise at end of self clean
    Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
    Anonymous
    • 187 Answers
    • Posted on Dec 14, 2009
    SOURCE: bake element does not heat up
    This would be a good candidate, but not necessarily an absolute. Selector switches, loose wires, fuses, and a few other sundries could also be the cuprit. Make sure that the new element that was installed is the correct one for your model. I am assuming that the element was replaced?
    If not, by all means, check the element. Elements only last a few years. Just because the plug it plugs into has current, it doesn't mean that the element itself is any good. By far, a burned out element is the most common, easily fixed failures.
    Unplug or shut the appliance off at the breaker. Pull the element and visually examine for burnt or rough spots. The elements either pull directly from the housing, or are held in place with a few screws. Bad elements sometimes look totally normal.
    If the bottom and top elements are the same( they usually are) a simple check would be taking out the broiler element and then swapping for the bake element. If the broiler element works in the bake position, buy a new element and ask for a refund for the service call.
    I can't understand why the service person did not pull the unit and check voltage in the control before making an absolute diagnosis. The circuit board is usually well over 100.00. The unit also sometimes comes with a diagnostic feature that homeowners/techs can use to test the "ERC" without even taking it out of the range.
    If you have your owners manual, check the trouble shoot section. If not, Sears has some manuals and repair help/parts online, and Whirlpool is among the best companies in terms of customer supports. I don't know your model, so I can't be too specific with advice. The link for Whirpool has a search engine you can use for your exact model. This link is for most newer models. Among other online resources, Repair Clinic" has parts that you can order online, and they also have diagrams that can help out significantly if you do change the unit out yourself. If it is something cheap like an element, it is helpful to go to an appliance store where you can return the unit a little easier. Thanks for your question, please leave comments if you need further advice.
    barkencoa
    Barry Coates
    • 3463 Answers
    • Posted on Dec 29, 2009
    SOURCE: Whirlpool AKZ 446 Electric fan starts but oven
    Yes , the element is easy to replace
    Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
    This should solve your prob.
    Good luck..
    john504
    John Wardlaw
    • 31 Answers
    • Posted on May 09, 2010
    SOURCE: after cleaning this oven, all controls work, but
    most ovens element are pretty easy to remove. Now if you didn't and just pushed them up you may have just disconnected the power. Make SURE!! you 220volts are off before you attempt to work on any power. If control is off you should be ok to work on elements.
    Testimonial: "Thanks! I'll follow your advice and replug the elements."
    Whirlpool YWFE710H0BS0 oven no longer heats up.
    Check the elements for continuity with a multimeter. Sometimes the connectors draw too much current and can burn out as well. Both are easy tests. A runaway temperature can make elements fail because there is no thermostatic control, they just glow bright yellow..
    Whirlpool GR478LXPQ1 stove and oven top doesn't work?
    To be honest, it sounds like you purchased a secondhand, faulty appliance. Although it might be loose connections due to the move, the most likely issue would be the main board and due to the price of them, that is often a good enough reason to buy a new stove.
    https://www.google.com/search?q=Whirlpool+gr478lxpq1+stove
    Error messages are normally searchable, but not that one. Take it back or call out a Whirlpool Service engineer to diagnose, fix and set it up. It is a sorry tale and not an easy one to fix.
    https://www.google.com/search?q=Whirlpool+gr478lxpq1+stove+AM71+UI42EEWET+107
    My whirlpool polara shuts down in the middle of the self cleaning cycle..now it is turning off during baking. Is it a heat sensor?
    Oven comes on and off intermittently or heats very little:
    If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
    Or Why does it take the oven so long to bake?
    When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
    Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
    On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
    Or Oven safety valve needs to be checked with multi meter ohms / voltage
    ALSO Test the Burner Heating Element
    The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
    Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
    When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
    First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
    Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
    Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
    Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
    To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
    The reason for my free advice is GOD is good!
    My whirlpool fan assisted oven as now twice turned on and heated up without me touching it what should I do
    Why does my whirlpool gold accubake range display turns off?
    What could cause this ? We have a Super Capacity 465, ceramic top oven. Everything appears to work properly except, when turned OFF, the surface heating indicator light for the left back burner remains on...
    after pics see articles
    Stove will not turn off CHECK
    Temperature Control Thermostat
    If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
    Oven Control Board
    The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
    Relay board:
    Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
    : I offer free advice bcuz God is so good!
    Oven clicks as if it is relighting almost constantly.
    Old electric range ovens use a coil heating element called a resistive coil.
    This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
    The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
    Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
    Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
    GAS OVENS
    The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
    2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
    3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
    spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
    Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
    If it would not fix the problem, replace the bake burner and the igniter.
    There is a small chance for the spark module itself to be bad as well.
    The oven safety valve
    (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
    ELECTRIC OVENS:
    CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
    Oven off and on
    Whirlpool oven went beserk while i was cooking pizza. it locked itself and turned the broiler on and then wouldn't shut off. i threw the circuit breakers and after a while it let me open the oven but...
    2answers
    Older Whirlpool RB170PBX both ovens out
    these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
    Top Whirlpool Ovens Experts
    ZJ Limited
    ZJ Limited
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
