Question about Transcend Computers & Internet
Not initialized problem in hard disk - Transcend Computers & Internet
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Tip
Virtual memory settings
Windows XP
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab. In the Performance section, click Settings.
3. Click the Advanced tab. In the Virtual memory section, click Change.
4. The hard disk drive that is used for virtual memory will usually be the
5. same disk drive that Windows is installed on. Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be approximately 200 MB in size but should be higher than or equal to the recommended paging file size as indicated in the lower section of the screen.
Once the initial size is set, Windows will reserve this amount of space on the hard disk drive for virtual memory and it will not be available to save information on.
The maximum amount allowable can be anything above the Initial size setting, but it is recommended that it be at least twice the Initial size setting
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Toshiba MK5056GSY is not initialized
if it's a second disk you can initialize it under disk management. press the windows key + the R key and type diskmgmt.msc and press enter. search for the drive in the list and right click and click initialize.
May 14, 2012 | Toshiba MK5056GSY Hard Drive MK5056GSY
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
How do i get a new hard drive to recocgnize the external drive
Connect the external storage
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management
Check to see if there is a "healthy" partition covering the disk-space of the external storage device.
Jun 24, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I have recently attached a seagate hard disk with my pc already have a sata . the 2nd one is not detecting, help me
You have to initialize and format a drive before you can use it. A brand new unformatted OEM hard drive and installed it in my Windows Vista PC. The drive is connected to the motherboard via a SATA (serial ATA) cable, just like my original hard drive. This new drive was for data/backup. When I turned on the computer, the BIOS picked it right up. However, when I got into Vista, it did not detect any new hardware. I even went into the Control Panel and chose Add Hardware and let it scan for changes, but it didn’t find anything new. Windows Plug and Play If your drive isn't detected, there is no need to panic. Windows Vista is a little funny about this sort of thing, but it is quite easy to fix. The problem is that the drive is not initialized, so the standard plug-and-play procedure for adding a drive does not apply. First, you must initialize the drive, then it will allow you to format it. After the drive has been formatted, it will be ready to use.
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds. Your hard drive is now ready to be formatted. Formatting Your Drive Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Read more: http://www.brighthub.com/computing/hardware/articles/22069.aspx#ixzz0iPADjMwO
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Can't install external hard drive. Do not have disc or manual. When I connect drive to USB port, drive lights up and makes sounds, but does not show new hardware.
Most likely the drive hasn't been initialized. Go to start, right click my computer, then manage. Select disk management on the right column. A window should immediately pop up saying disk initialize wizard. Press next, and it will guide you through on how to initialize the disk. Make sure you format it as well, so that the computer will recognize it as a drive.
Dec 29, 2009 | Maxtor OneTouch III Mini Edition 120GB...
I have a printer it is modle is Hp LaserJet p4015n, when i start it give me this error: (49.00FF ERROR To continue turn off then on). when I turn off then on it give me agane this error. thanks for help,...
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
 NVRAM initialization
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
Dec 12, 2009 | HP LaserJet P4015N Printer
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
Disk boot failure
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Dec 09, 2007 | Intel Server Board SE7505VB2 Motherboard
Computers & Internet Logo
12 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
