Question about Germ Guardian Humidifiers
Blows fuse power board
Germguardian humidiers not turning on
Hooking up humidifier from the control circuit board of a furnace. keeps blowing circuit board fuse
What are terminal letters your furnace low voltage board? Which ones are you connecting to?
Oct 05, 2013 | Humidifiers
I have a HoneywelI Enviracare Elite whole house humidifier. I have no power to the thermostat. The wire goes into the furnace and is attached to a control board. The furnace is working. Humidifer is n
Most of the humidifiers are run by 24 volts AC. disconnect the power wire to stat on circuit board and check there with meter and connect to low voltage ground for 24 volts, I'm assuming the two wires that power the humidistat are red and white.typically red is used for power. most likely you have power if the red for the stat is connected to the W on the board and the heat works, but the humidifier only works while heat is on.the next thing in line is the humidistat , it's a switch so if there is only two wires going to it take them off the stat and connect together, if furnace is on heat and running and stat wires are connected it will send power to water solenoid, if its not working yet the problem lies in the water solenoid if you have 24 volts at the two wires at solenoid.check while disconnected, do not connect those two wires together or a 3 amp fuse will blow on the furnace board. if you have 24 volts there then the valve may be bad or the valve may be stuck or clogged, loosen water supply line to make sure water is getting to valve. I spent many years working in the HVAC industry.
Dec 31, 2011 | Honeywell Humidifiers
Pn:152Z0027KGM
Here is a link to parts for your humidifier http://www.aprilairehumidifierparts.com
Nov 11, 2011 | Aprilaire 550 Humidifier
Hi, I was cleaning my H3010 Germ Guardian Humidified and damaged the small round part with 2 wires (JR707). It is the part where the water mist comes from. Is there a way to buy this small thing ot...
For replacement parts contacting the manufacturer of the humidifier would be the best thing to do. They know what parts can be replaced and if they have service repair facilities or if you would need to work directly with the company. Germ Guardian website is www.germguardian.com. Toll free 1-866-603-5900.
Apr 09, 2011 | Germ Guardian Humidifiers
Too much humidity on windows
Depending on were youre humdistat is mounted either on tha return duct near the furnace or on the wall in the living area this should be an easy fix turn the dial down there is is to much humidy.
Nov 03, 2010 | General Filters 1042-LH Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
Honeywell furnace humidifier thermostat & other
sounds like to me you have a condensation pump attached to your hvac system. this can be used to pump water produced during the cooling of your house when in the a/c mode. if you have a typical bypass humidifier, you will have excess water running past the water panel and it must be sent to a drain of some kind. I would imagine the pump is being used to get your bypass water to the drain. another scenario may be that you have a 90% condensing furnace. if your exhaust pipe for the furnace is made out of pcv pipe, it is a condensing gas furnace. it will produce water when it is running. the water if from the combustion gases being condensed in the secondary heat exchanger. this is normal. some condensing gas furnaces will draw combustion air from inside the house and some will have a second pvc pipe that is used to pulll combustion air from the outside of the house. either way, it is not dehumidifying your house. the humidifier should be able to keep up if it is runnng properly. you should have water running out the bottom drain of the humidifier any time the fan on your furnace is running and the humidistat is calling for humidity. if this is not happening, it is not wired properly.
Jan 16, 2009 | Honeywell Power Humidifier: Furnace...
Humidifier by Hunter
if you are constantly heating the house, your heter element in the furnace is drawing in and drying out the air you are humidifying. Heat the house, and then turn on the humidifier while the heater is not running. Is your humidifier able to do your entire house (whole house) or just a small room unit?
Dec 26, 2008 | Humidifiers
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
56 people viewed this question
Top Germ Guardian Humidifiers Experts
Paul Carew
Dennis
Are you a Germ Guardian Humidifier Expert? Answer questions, earn points and help others
