Question about iHome IDM8 Bluetooth Speaker Black
Doesn't turn on
No light at all even it is plug on
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Computer doesn't turn on. Tried just using AC plug in with no battery but doesn't turn on. When the AC Adapter is plug in there is a orange light on when battery is in and a white light with
If you are still having trouble I would take it to a local pc technician. I have had good luck an UniComputers on 23rd st but its not cheap...
Sep 30, 2012 | HP Pavilion g4-1117dx Notebook
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Hi, someone gave me a Hitachi 50VS69A TV and it doesn't turn on the lamp light flashes. But the power light doesn't even go on?
Have you since the lamp light is on even removed and inspected the lamp to see if shattered or not?
Apr 22, 2012 | Hitachi Televison & Video
My car will not start my lights, radio work its not the battery. I recently replaced the starter, the altenator, battery, fuel pump catalyic converter. when i turn the key there is no noise it won't...
Sounds to me like the starter or starter relay, OR did you check all the fuses? When the starter doesn't click or turn over the engine it is likely a problem with it or the power supply to it. Start with the easy thing. check the fuses, then the relay.
The P0300 is usually caused by something other than the spark plugs or coils. A fuel/oxygen sensor can cause this code. I would say that doesn't have anything to do with not starting.
Good luck.
Thanks for using FixYa.
Gaker
Jul 22, 2011 | Ford Expedition Cars & Trucks
iHome IDM8 Bluetooth Speaker Black Logo
42 people viewed this question
Top iHome Audio Players & Recorders Experts
Wesley Elsberry
Wesley Elsberry
Level 1 Expert
ray gallant
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
