If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
For most radios, select a station you want, then chose which preset you want it at and press that preset button for 3 or 4 seconds to lock that station in that preset number.
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
Hi - I had the same problem setting up my 3G S. Here's the solution. In "Settings/General" set the Bluetooth to "ON". Turn your ST3 OFF by holding the green button until she says it's Powering Down. Now press and hold the
green button ON until Language Selection (British
English) option. Select language by pressing green
button again. Next she will say "Device Found-Paring Successful-Enter password 0000". Enter 0000 and your phonebook will start downloading. There ya go!
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
You can add flash menus, change camera driver, change acoustics, add languages with FSX
You can upload stuff to phone either with own_custpack method or via FSX
Rest all remain same. Here is a list a of directories with information. Download the stuff and upload them
ifs/settings/acoustic/ >> Acoustics file
ifs/settings/camera/ >> Camera driver ifs/settings/display/ >> Display driver
tpa/preset/system/desktop/flash >> flash menus
tpa/system/layout/ >> layout.xml tpa/system/system/mutlitmedia/mp/skin >> Walkman 2 skins tpa/system/preset/multimedia/pe >> frames , clipart etc tpa/system/preset/multimedia/av >> visualizations
tpa/user >> stock pics and themes…
pa/preset/system/settings >> startup and shutdown screens ! all are GIF but with no extension tpa/preset/system/sound >> all sound files tpa/preset/system/menu >> the famous menu.ml tpa/preset/system/fonts >> fonts ! /usb/audio >> locked music (can be deleted with FSX only but not with phone) /tpa/user/audio/ locked music /tpa/preset/default/audio/ locked music /USB/IMAGE >> locked images.. can be deleted /tpa/user/image/ >> locked images /tpa/prest/default/image/ locked images ;Locked Themes -> /USB/THEME ;Locked Themes -> /TPA/USER/THEME ;Locked Themes -> /TPA/PRESET/DEFAULT/THEMECheck out the FS for more directories and locations Please check out the customization of phone tutorial for more. You can use either own_custpack method or FAR MANAGe thanks rate it................
