Question about Garden
Sanli mower backfires threw carby
2 Suggested Answers
SOURCE: mower engine backfires through air filter! will
A: Backfiring (and misfiring in general) can be caused by a large number of problems; unfortunately not only you do not even say what kind of Fulvia you have but your description of backfiring is superficial. You certainly have not attempted to exclude some obvious causes of backfiring. With these limitations I can only try to list a number of potential causes and how to solve them.
  1. None of the things you have done (plugs, cables, alternator, filters etc)has anything to do with backfiring. I am not surprised that no improvement was obtained.
  2. You must check that the valve timing is correct and that the timing chain has not jumped one tooth of the camshaft sprockets (details will depend on the car engine). Ensure also that the valve clearance is not badly out.
  3. You must check that the ignition timing is neither too advanced nor too retarded and that the correct dwell angle is set with respect to the points opening gap (details depend on the engine).
  4. It is unlikely that the problem is due to carburettor malfunction: however, check that the two carb floats are OK if everything else seems fine. I presume that by inspecting the spark plugs you concluded that the carb air/fuel mixture was basically correct.
  5. A leak in the intake system can cause backfiring but you do not even say if your car has a brake servo (some Fulvias did not have one). It is very unlikely that the servo is causing your problem since you would notice that a strong effort is needed to stop the car and that the same amount of brake pedal pressure can be applied with the engine running or switched off. It is possible, that the vacuuum hose running from the cylinder head to the servo (or its one-way valve) is damaged: a crack in the vacuum hose occurs very often although I have not seen it to produce symptoms as bad as the ones you describe. Any vacuum hose (with suitably rigid wall) of the same diameter will be OK to replace yours: it does not have to be a Lancia product.
  6. Your car may have a leak either in the carburettor rubber support or in the intake manifold gasket.
  7. I do not know if the Polonez servo can fit your Fulvia. Reconditioned servos can be obtained from commercial suppliers but I suspect that the servo itself is not the cause of your problem.
  8. Poor throttle response (when everything is tuned up correctly) can be due to failure of the centrifugal advance mechanism in the distributor (broken springs, stuck bob-weights etc) or to inefficient acceleration pumps (holed diaphragm) at the bottom of the carbs. However, neither of these problems should create backfiring.
  9. Fulvias do not necessarily start instantly from cold because, if the car has not been used for some time, the carbs must be primed, a process which takes a bit of time as the fuel pump works while the engine is spinning. Some people have fitted an electric fuel pump to prime the carbs. Of course, using the choke will help starting from cold.
Finally, it could well be that, after you have identified and cured the problem, you must balance and tune the carbs. It is easy to blame carburettors for all sorts of misfiring problems: in practice, they are very robust and long lasting but they should be balanced properly by measuring simultaneously the vacuum created by each carb pair at the appropriate plug hole in the intake manifold.
Posted on Apr 08, 2010
Husqvarna 18538 engine starts smooth but starts popping like backfiring . Trying to figure it's old gas ? Just serviced the machine.
to most owners a service means change oil. plug ,and clean air filter
drain the fuel tank ..new gas
cant see the carby .. if it has one
undo fuel drain nut on side of carby bowl
popping ....check valve adjustments
if no better
you may have a burnt valve
May 31, 2016 | Husqvarna Garden
Briggs &stratton 11 hp
timing issue. Remove the flywheel to see if it has "spun" from the keyway. If the motor doesnt run at all but just backfires thru the carb, it could also mean really bad intake valves, but I would definitely check the timing first
May 14, 2014 | Briggs & Stratton Garden
Triumph herald backfires
check the vacuum hose to the carbies There is a hose that controls the plungers in the carbies
Nov 07, 2013 | 1988 Ford F 150
How to remove silver cover on front of engine
Bumped a tree and the mower died ?? If so, you broke the Keyway on the flywheel which threw off the Timing. Flywheel has to come off and a new keyway ( very cheap) has to be installed.
Aug 24, 2013 | Husqvarna 21" Lawn Mower with Honda GCV160...
Scag wildcat STWC61V-26KA-LC backfiring
check for loose carby or failed carby to manifold / head gasket as it appears that you have a lean mixture problem xcheck for blockage in main jet.
Jun 12, 2013 | Garden
Lawn mowers
clean air filter, clean out carby bowl and main jet
Jun 03, 2013 | Garden
Cub cudet 31p7770299e1 briggs stratton engine
only thing left is valve seat is loose and poping loose at a certain rpm causing backfire threw carb has to be intake valve
Apr 23, 2013 | Cub Cadet Garden
I have a sanli mulcher lawnmower about 3years old, always ervicedand looked after. last few uses its been gutless. today it was running but stopped. when I went to restart it, it made ratchetting sounds,...
Never heard of a sanli. If the engine is backfiring, indeed it could be out of time. One sure way to check if it is out, is to see if the flywheel key is sheared.
Please vote on this solution.
Sep 05, 2010 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
