Question about Samsung Washing Machines
Front loader model WF1752WPC
Stops during cylcles with SUD message on the display
mewms_14904
  • 1027 Answers
SOURCE: Ariston washing machine front loader
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
Posted on Apr 11, 2008
  • 193 Answers
SOURCE: Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Posted on Nov 04, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
  • 2468 Answers
SOURCE: I have a kenmore elite he3 front loader; it gives
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Posted on Jul 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Posted on Sep 26, 2010
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
I have a Samsung eco bubble WF1804WPU model that started showing the error message SUD. Any time it happens the machine stops washing as if paused and I have to press the pause button twice for it to start...
The SUD error indicates an excessive amount of soap suds in the wash. It will be difficult for the machine to rinse / spin all the soap out during the cycle, and may need to be run thru the cycle again (do not add any more detergent!).
Remedy:
Stop using regular detergents! Front loaders specifically call for "HE" (High Efficiency) detergents as they require less detergent and clean better with the reduced amount of water in these machines. Look for your favorite brand and select the one with the distinctive HE logo show below:
Use only the amount as directed on the bottle - do not use too much. Clothes should come out clean and soap free - and the SUD error should no longer appear - if it continues - double check the amount of detergent you're using as it is probably still too much.
Jan 30, 2015 | Samsung Washing Machines
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag 3000series front loader model number mhwe300vf00 on the display it says sud what does that mean
Being a high efficiency washer, this model uses less water. Not all the soap suds have not been rinsed away. Most likely you are using the wrong detergent. Use detergent with the he label on it.
May 23, 2011 | Maytag Washing Machines
It flash's SUDs during the cycle.what does it mean and what can i do to stop it from doing it
The SUD message indicates the control or pressure switch senses suds in the water. Run the machine empty with hot water only to clear any soap residue out of the machine. Cut back on the amount of soap used and use only HE detergent in the machine.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
SUD in display
The SUD message relates to overdose of detergent detected during the Wash Cycle.This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked.
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our washer shows the message "sud"
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
SUD message appears
My manual says that Sud means that you are using too much soap. The washer will say this mid cycle until it gets rid of the extra "suds" and should then resume the cycle. If it doesn't, then you have a different problem.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
