Question about Dewalt Dc012 worksite radio
Dewalt dc012 replace pack indicator light keeps flashing
HI. I have a Dewalt 20 volt impact the lights stayed on for long time now it stopped working all together when pulling trigger
Are you referring to the percentage of charge indicating lights on the battery pack? If so, the battery is most likely bad. What did the flashing light on the charger indicate when you tried to charge the battery? There is a flash sequence (called out next to the light) that indicates if there is a battery fault.
Aug 26, 2017 | Dewalt Drills
I have a Dewalt charger/radio (DC012 type 1) that was plugged into a 240v US outlet. The radio will come on with a battery in and work just fine, but with it plugged in it will not charge or play.
You burned out the AC circuit. Congratz, at least your radio still works. Use it on battery or take it to a radio technician to diagnose if it can be repaired. Presume it's worth.
DEWALT DC012 Worksite Charger Radio
Jun 25, 2015 | Dewalt DC012 Worksite Charger/Radio
Dewalt radio problems
The resistor of the potenciometer at volume is malfunction.
Change the potenciometer.
Sep 03, 2014 | Dewalt Dc012 Cordless / Corded Worksite...
Dewalt dc012 won't run on 120v?
change tranformer for converting 12 volt from 110
May 06, 2014 | Dewalt DC012 Radio/charger,120v Ac Or 7.2...
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
I need to know if there is a fuse in the dewalt DC012 worksite charger radio
From what i gathered there are two
Fuse (part No. 5140019-09)
Fuse 1A (part No. 429790-32)
Jan 06, 2013 | Dewalt Dc012 Cordless / Corded Worksite...
My Dewalt dc012 radio will not work while plugged in, it only works with a battery
There is a small transformer which is used to lower the voltage for the radio to use (12 Volts I think) These transformers have been known to be defective at times. You can pick one up at the Dewalt store for about $25.00 and install it yourself.
Dec 29, 2012 | Dewalt Dc012 Worksite Radio With Built-In...
DeWalt 18v batteries charge light flashes quickly why?
Here are the codes for Dewalt Charger Flash indications:
---- ---- ---- ---- ---- ---- ---- Charging
------------------------------------ Charged
----- - ----- - ----- - ----- - ----- Hot/Cold Pack delay
- - - - - - - - - - - - - - - - - - - Replace pack
Feb 07, 2011 | Garden
Dewalt Dc012 worksite radio Logo
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
