Question about HP P2055DN LaserJet Monochrome Printer
Possible problem with network cable. Had similar problem, which was solved by changing network cable
Need help with a wusb54g ver4 network adapter
You are say link light means network light not on. Then you check network cable because network cable not proper response not link light on. or check you not break any cable. If possible reset Linksys adapter and wait some time then open and configure i hope solved your problem. If not solved then contact Good network engineer.
Thanks.
Computer Support
Mar 06, 2014 | Linksys Wireless-G Broadband Router
W902 no signal and not charging
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.For charging:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 06, 2012 | Cell Phones
HOW DO I ACCESS WEB CAM WITHOUT THE CONSENT. WHAT BEST FREE SOFTWARE ARE AVAILABLE FOR COMMON MAN
Web camera chatting is made possible with compatible computers, network structures, also mentionable are camera device peripherals. The computer compatibilities allows to camera install programs that makes chatting on networks achievable. For example, acquire computer that are web camera comparable also of recent innovations have built-in features least requiring user manipulations to attain experiences. Once acquired a new computer of recent age, a built in camera performs as capture device for programs and network requirements. Recent wireless networks override the request to install cable structure that makes telecommunications possible. Installing a wireless connection to share signal makes convenient the media sharing capacities especially on computers with built-in cameras. At which point the computer networking and resources requirements have been accomplished. Similar structures elsewhere on the network makes possible web camera conferencing achievements. Usually the computer requirements have been satisfied. The remaining processes are achieved as customization requests. For example, the networked computer teleconferences with common programs on each computer devices. Usually informing the chat entities to acquire similar programs overrides the compatibility miscommunications. For example, requesting for chat conferencing to be achieved on yahoo messenger or msn massager, daybook chat or YouTube chat messaging where each entity acquires the details in computer structures overrides the compatibility malfunctions. In which instance, chat communication should least expect malfunctions. Chat conferencing becomes cost incurred when each member entity places charges on the process to arrive at message telecommunications. Also, in the situation where an entity lacks computer resource structures that has cost incurred compromises the free nature of telecommunication.
Feb 11, 2011 | Computers & Internet
Changed network and now the internet wont work
iewty
changed network and now the internet wont work
Solve this problem: Enabled Pocket PC... Is it possible to install Android on the X500 instead of Windows Mobile? Close Answer Bid Solve this problem: what type of memory card does xda ii use?
Oct 26, 2010 | LG KU990 Viewty
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on.
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
Dec 20, 2009 | HP P2055DN LaserJet Monochrome Printer
When starting internet explorer ''no connection'' problem
can you restart the netgear? also see if you can connect ok with a cable. After all these, reboot your PC and check
Jul 08, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Sharing of internet connection
You need to purchase a router and two network cables to connect the computers. If your computers do not have ethernet connections then you need a wireless router and two wireless network adapters for the computer. II recommend the Linksys W300N or similar for the router and the Linksys WUSB300N or similar for the network card. There are very simple set up instruction with the router and cards.
May 23, 2009 | Microsoft Computers & Internet
Cant connect to web with ethernet cable
Well what setup do you have, single computer? Make sure your network adapter works, is the key..run cat 5 cable from computer to modem and modem to wall outlet. If possible try your network adapter on another computer.
Feb 19, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Network or usb cable
Look on the back of the printer. If it's possible, you'll see a USB connector that looks kind of like an arch or doorway. If so, use a USB A to B cable to connect it to your PC. Make sure you use the drivers for a USB connection when reinstalling it.
Jan 14, 2009 | Kyocera Office Equipment & Supplies
Ethernet cord
Hi Dear Friend,
There can be number of reasons for this problem. To solve the problem, you can try these:
1. Check that RJ 45 connector, connected to switch/hub/pc is showing LED indication or not at the both the ends i.e pc end and at the switch/hub end.
2. Make sure switch and pc configuration should be correct and is not changed by mistake.
3. If LED indicators are not glowing any of the ends i.e PC or Switch end there might be a problem of ethernet cable, possible broken/cracked cable at some place or also possible that RJ 45 connector problem.
4. Also try the same cable to connect to different pc. Check, if it work then or not.
Hope this will solve the problem.
In case any other info is required pls. feel free to contact.
Thanks
Aug 02, 2008 | Kensington Portable Ethernet Cord (33052)
HP P2055DN LaserJet Monochrome Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
