Question about GE VG4062 VHS VCR
Need to turn off timer - GE VG4062 VHS VCR
Need a good vacation timer. Any suggestions?
Copy following link to see analog vacation timers that turn lights on at random times.
Set current time slightly different so lights inside house can turn on-off at slightly different schedules.
Rotate dial to set current time, plug timer into outlet, make sure bulb is good, turn light ON, and plug light into timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#vacation
Multi-function digital timers, such as Woods 59377, and lifetime-warranty Intermatic DT620 also have vacation feature, and timers have 2 outlets, but programming is more complicated than using analog timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Jul 13, 2012 | Hardware & Accessories
I just replaced my filters and turned on the power and now I get nothing?
More information is needed.
Question posted under Intermatic T101 120Volt timer. Timer model number appears on inside of timer door. Add a comment any time and it sends email and I will respond.
Open following link for Intermatic timer troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
When you turned off power, did you turn off circuit breaker? Or turn off manual override on timer?
If circuit breaker is turned on, does the timer dial rotate?
If timer dial rotates and keeps good time, then electricity to timer is good, timer clock motor is good.
If dial is rotating, what happens when you move override lever back and forth? Does load turn on?
Read through troubleshoot on link above and then add a comment with more details if needed.
Sep 17, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
Timer turn on but doesnot turn off
New timer is probably wired wrong, or older timer probably needs new trippers.
Open following link for troubleshoot walk-thru:
Jul 13, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a Tork 1104 FM timer on my pool. It was not turning off, so I replaced the trippers. Still not turning off. The timer turns the pool on, but not off. Must do it manually. Any suggestions?
The internal mechanism will wear and then the timer mechanically will not turn of...but if you do it manually the contacts will break, shutting the load off...
You will need to replace the complete timer...there is no way to rebuild the mechanical part of the timer...
heatman101
Jun 28, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
York timer controls pool pump. When I want to turn the pump off for maintenance, the "Off" lever will not stay down and turn the unit off.
More information may be needed.
Turn off the breaker to turn off power to load.
If this is a mechanical timer, and the override lever is not working, turn off power at the breaker.
Use WD40 to see if you can loosen the lever.
With mechanical timer, usually when override is not working, it signals you need new timer.
Add a comment and describe timer and what you have tried so far and what solved the problem.
Add a comment with in-focus photo of your timer posted on Flickr for possible identification and more complete help.
I cannot find reference to York timers on the web to recommend a replacement timer.
If timer is 120V then Intermatic T101, or if timer is 240V then Intermatic T104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Intermatic competitive reference crossover guide does not show York brand timers as of right now.
You might have a Tork timer?
http://waterheatertimer.org/Tork-timers-and-manuals.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | York Hardware & Accessories
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Is a globe outlet timer supposed to turn when plugged in? it is a "pin" type
Yes it turns when time passes.
If timer is not turning, it is broken and needs to be replaced, or the electricity is off.
Oct 2010
Add a comment if you need further assistance
Oct 28, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
Gets stuck in cycle I have to turn the knob to get it to continue. The machine is the heavy duty large capacity I can't find a model #
Looks like you need a timer. If the model number is really gone there should be a part number n the timer. look everywhere around the door/lid and even on the back. Eric
Aug 12, 2009 | Washing Machines
T101 Intermatic Timer will not turn lights on or off
You have a weak timer motor. The T101 is notorious for it. I have 6 on my property and have had that problem numerous times. You need to replace the guts of the timer.
Jul 05, 2009 | Hardware & Accessories
Dryer not heating up
If the timer knob does not turn in a clockwise direction, then chances are the timer is bad.
Heating is a different issue, although, if the timer knob will not turn, then it may not be at a position that turns the heat on.
Replace the timer, then check the heating. If the heater then works, then the problem was in the timer. If it doesn't, then we need to look at problems within the heater circuit.
Reply back what you find out.
Jan 23, 2009 | Whirlpool LER5636P Electric Dryer
Televison & Video Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
