Question about Philips Philishave HQ7780 Electric Shaver
Philips hp 1335 wire connections
Motor red wire connection to printed circuit board
3 Suggested Answers
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
  • 76 Answers
SOURCE: philips crt television model 27k261 won't turn on.
Sorry. I would play games with AC. Call the Tv repair man.
Posted on Mar 18, 2010
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
I have zanussi ZWH 6140 P WATER WONT DRAIN ERROR CODE 5 FLASHING RED LED LIGHTS?
First, always check carbon brushes on main motor especially if the appliance is in use for several years.
Five times the red alarm means a problem with the engine washing.
So, could be:
E51 - Motor power triac short-circuited.
Current leakage from motor or from wiring; Main PCB faulty
E52 - No signal from motor tachometric generator.
Wiring faulty; Motor faulty; Main circuit board faulty.
E53 - Motor triac sensing circuit faulty (wrong input voltage to
microprocessor). Main circuit board faulty.
E54 - Motor relay contacts sticking (high voltage level when
the relay switches to OFF).
Current leakage from motor or from wiring; Main PCB faulty;
Rapid reading last alarms:
Press the START/PAUSE button and the nearest option button simultaneously (4 and 6) for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
zwh 6140 p-dd5v0vxzvbk4xzho0hm3qdol-4-0.jpgDado
Mar 01, 2017 | Zanussi Washing Machines
Table fan winding&connection daigram
  • I have a Bionaire brand table electric fan.
    • It has a 3 speed fan motor.
    • The electric motor is a BM-122 Decomin brand 3 speed motor.
      • There are 6 wires:
        • Red wire.
        • Black wire.
        • White wire.
        • Yellow wire.
        • Gray wire.
        • Blue wire.
          • The motor has a 4mu 250volt capacitor.
  • This fan has an oscillating grill with independent sync motor, and timer circuit.
  • Something was wrong with the solid state circuitry (everything worked but the motor!), but a quick test of the motor indicated it does work.
  • The motor uses a start and run capacitor.
  • I decided to change controls to a simple mechanical switch and fore go for now anything beyond 3 speeds.
  • The printed circuit board shows the following connections:
    • Black wire
    • Blue wire
    • Yellow wire
      • Are respective for the:
        • High fan motor speed
        • Medium fan motor speed
        • Low fan motor speed
  • I think the gray wire goes out to the oscillator motor.
    • The Red wire is marked as Line, for the power source.
  • All wires are in continuity with each other EXCEPT RED is not with any other wire. How to Verify Fan Motor Wiring Connections
    • Checking the Motor and Capacitor Connections
    • Double check your connections using the fan wiring diagrams.
    • You should see that there is a separate motor winding for high speed.
      • The concern is that there is a capacitor for the motor.
      • So I'm thinking that the motor may have to start with the slower speeds first.
      • and not start in the high speed because the motor or capacitor has not been designed for that type of operation.
Sep 29, 2016 | Dryers
Should there be a red or orange wire connected to the circuit board ?
On a heat pump A/C unit the orange wire going to the thermostat operates the reversing valve. default is the heat cycle. Without the orange wire connected the unit will only run heat. Most straight cool units have no orange wire. Red wire to the thermostat is for 24 volt DC. Red wire to the blower motor is low speed Black is high speed. Hook up both and MELT THE MOTOR !
Nov 08, 2014 | Heating & Cooling
I was expecting to find this relay. It's not there. My unit has a rather complicated looking circuit board. The circuit board seems to have been made by Emerson Climate Technology. On the top edge of...
this board needs a 24 volt supply run from the furnace to power up the communicating board
check your wiring diagram on the inside of the panel this will help you
Apr 04, 2011 | Amana Heating & Cooling
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
Electrical Short in Printed Circuit Board.
Hi, do you know what these wires were for? You can bypass the board, but if the wires are for lets say the blower motor and you bypass and put them to direct hot legs, you will run all the time, or what ever shorted the block in the first place must have a short. Its probably in the wires at this block and if you apply it to 120 volts it may fry again. I would follow these wires back to see what they run first. Yes, it can be done.
Shastalaker7
Jun 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
Have two wires disconnected from a carrier hvac unit that goes to supply air fan. they are 4 wires total. one yellow goes to l2 on circuit board and red to bm, the black and blue wire is not connected...
Hi, these wires control the speed of the blower motor.L-2 is one power leg and red to bm (blower motor). If the other 2 wires are wire tied out of the way, and they have always been this way, that's the way they come from the factory, to control different speeds. On a 230 volt blower motor, you will see a yellow which normally goes to L-2 on the board. Then you will have a black, red, and sometimes blue. Sometimes you will see L-2 with yellow, L-1 could be any one of the other colors as they are marked on the motor. Low, Med, and High speed are what these extra wires are for. So, you are only using 1-speed. If it is running, and has been, forget the other 2 wires. If its not working, look for a L-1 on the board and connect any one of the other 2 wires. Like I said though, if this is always how its been and running fine, this is a normal termination. Let me know if you have a motor problem, and I can walk you through it.
Shastalaker7
PS The BM red wire is L-1 on the board.
Dec 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Philips Philishave HQ7780 Electric Shaver Logo
146 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
