Question about Invicta Dragon Lupah 2094 Wrist Watch
Watch band size - Invicta Dragon Lupah 2094 Wrist Watch
Maxum Watch Band X6003L2 - Australia Need a replacement band, but distributor says it can only replace whole watch not band. It is only 18 months old. Any advice?
You might be able to replace the band with a generic watch band (meaning a band that will fit the watch but is not the exact band that it came with) Some good companies would be speidel or Hadley Roma to get the bands from. Just find out the millimeter length (or the size of the band) and you probably could change it.
Jun 26, 2013 | Watches
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
May 05, 2011 | Disney Goofy Brown Leather Strap #D075S007...
I need new band
If you need a new band for RADO watch, you can pop in any watch shop and choose whichever band you like. The only thing you have to remember is; get the right size. Right size for you watch is the size between lugs in millimetres. Lugs are the things where the band gets attached to the watch. Measure that distance - this is the size of band you are looking for.If you are after original Rado band, then you will have to pop into your nearest Rado dealer shop and order it. The real thing will be far more costly.
Mar 01, 2011 | Rado Diastar Classic 300M R12639023 Watch...
I need a leather band for my male cartier roadster
mcdevito75 here, Ebay is your best bet for the Leather band for your Cartier watch, but! you:ll need to know the MM size of the band. Measure the width of the band just as it hooks onto your watch, use a ruler, most rulers have both the MM scale and American, if your ruler has only the American mmeasurement use the online Standard to MM calculator for the MM size from the American or standard measurement. Carefully measure the width of the band just as it hooks onto the watch, count the segments in the ruler either each MM or each 16 th of an inch, convert to MM then look on ebay for the strap.
Aug 28, 2010 | Cartier Roadster W62016V3 Wrist Watch
Pins keep popping out when watch band gets snagged. What size are the pins for watch band?
mcdevito75 here, These pins may be a bit worn in the band of your watch, if so, you"d have to order a kit with various size pins for replacement. BEST BET, look for a small watch repair shop to fit new pins in the band.
Jul 12, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Need a new watch band
mcdevito75 here, Ebay is a great place for your watch band, but you should know the watch band size in MM, or you can look for a small watch repair shop in your area.
Jun 17, 2010 | Locman Titanio Tonneau LOC/484/CRBRD/BK...
What size band do i need for a kirium watch (rubber)
Distance between lugs (the place where the band gets attached to the watch) is the size of band. Get ruler and measure it. Rate me plz.
Mar 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
Size watch bracelet
your band is Skagen Signature Mesh
http://www.skagen.com/service/watchInstructions.fx#adjustment
Dec 26, 2008 | Skagen Watch
Need a watch band for model 746 timex digital watch
I would suggest going to walmart or a jewelry store. Walmart has lots of different styles, materials, and sizes of watch bands. They will usually put the band on and fit it to your wrist size.
Aug 30, 2008 | Timex Watches
Invicta Dragon Lupah 2094 Wrist Watch Logo
14 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
