Question about Night Owl Optics Explorer NOCX3 Monocular
How do i turn it off
There is still green vision. how do i turn it off to save the battery.
Accidentally left canon cybershot in freezer for a day
It would have been better if you hadn't turned it on. Take out the battery and let camera and battery dry out thoroughly and warm up to room temperature. Once all the condensation is gone from the screen, reinsert the battery and try it.
May 14, 2012 | Cameras
I bought a Night Owl Vision Cyclops 1 monocular marked Made in Russia from a man last weekend at a flea market. It is in pristine condition and the gentleman said it worked but he hadn't used it in a...
Hello, Is there two switches on the NV monocular? If so, one is for the IR illuminator and other is for turn the scope off/on. Also, does each switch have a LED associated with it? Green for turning on the monocular and red LED when the IR illuminator is on. Now the IR switch is a momentary switch once you push on the button it turn on IR. If you release the IR button it turns off the IR..
What do you mean by green lightening storm in the view finder? Generation 1 image intensifier tubes when ignited by 15KV it will glow green in the tube. If you look through the eye pieces there will be a green glow with fluctuating intensity as bright light impact the plate in the image tube. GB...stewbison
Aug 22, 2011 | Kalinka Zenit NV CH Russian Night Vision...
I have an Aries mk 208/230? night vision sight that's been sitting in the closet for several years. I put the batteries in it and it failed to work. I bought a new battery for it and it still does not...
As you probably know that internal electronic are manufactured in Russia. I just repair an ATN MK238. Verything from the image intensifier tube to power supply was shot. I managed to round up 1 gen green Russian image tube, but the ccfl inverter, tolorid coil, voltage multiplier I had to manufactured them. Sorry, wish that I could be more help. stewbison
Aug 09, 2011 | ATN American Technologies Network Aries...
I dont have a manual with my paramount night vision. how do you operate it. i can get a red light but thats all.
Hello, You should have two switches, one for on/off and the other for IR intensifier (red). There should be or not two LED one green to indicate on/off--no green LED it off, if the green LED glows green it on. The same with IR luminator, red is glowing the IR is on, if not glowing red, it off.
Make sure you have new batteries and make sure that the polaity is correct---positive +,
negative -.
Push the on button, if you push the right button the green LED will glow, then push IR button. Put you hand in front of the monocular and see if there is a red glow on the palm of you hand, if there is then the IR is on. Never look into the IR lens. Now you can look through the eye piece.
Now, if there no green tent inside of the monocular then there are other problems with you NV devise.
Never, and I mean NEVER look at bright light at night or in the daylight. This will destroy the image tube. That is one reason why they are call night vision....Only for viewing in the dark. stewbison
Aug 08, 2011 | Bushnell MOONLIGHT Night Vision -...
My bushnell night vision is blurd nothing to see..what should i do?
Hello, when you turn on you Bushnell NV devise does the green come on , looking through eye piece. If it a white oval screen, then check the batteries and make sure the polarity is correct.
If you don't have the green screen in the image tube. Then it not working normally and they is a good possibly that the image intensifier tube is bad. Contact Bushnell ask them what it cost to repair it. stewbison
May 24, 2011 | Bushnell Night Vision Goggles 1x20
There is not picture its just vioce
Battery OK, IR light up, no green image on the intensifier image tube, correct! What type of voices are you hearing? Give ATN Aries 390 two Zolof and wait two day, just kidding!!! The noise is a crackling, high freqencey hum, popping, etc. Also remove the eye lens, it screw off, then remove the scope to someplace where it semi dark. Turn it on and observe the 18mm white plate and see if it turn green---no green---no look see---no image intensifier tube, it dead that is the mage tube. stewbison.
Mar 15, 2011 | ATN Aries 390 Paladin Weapon Sight
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
Feb 26, 2011 | US Night Vision Ultra PVS-7B Goggles
I can't see any object in my night vision monoscope. The batteries are new.The indicator IR and ON are illuminated when switch to on.Please advice. Thank you very much. Respectfully yours, Remigio...
Hello, did you turn the Bushnell on. There two switches one for the on/off the other is for the IR and it say on as long as your finger pushs the button. Have you used during the daylight hours, looking a bright lights. If you have, the NV has gone south in one hurry.
If want come on even though the on/off switch working. If the NV devise is work there will be a green LED on the back indicating that the devise is on. stewbison
Feb 02, 2011 | Bushnell 4x50 Prowler Night Vision...
Zen Vision M
If you reset it and it goes back to just the zen screen, then I had this problem once too. You need to go to recovery mode (which is still possible).
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
    If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole,
press gently and remove.
It will display the following options.
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.Here's the link to the site where I got the info from. (it's another forum). Good luck!
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=151527#M151527
Jan 26, 2008 | Creative Labs ZEN Vision:M Digital Media...
Night Owl Optics Explorer NOCX3 Monocular Logo
46 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
Ted Maxwell
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
