Question about GE Profile ASM10AA Air Conditioner
Air conditioner lights come on etc but won't go
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
Bucket full light is on, I have drain tube out the window, air won't work. How to fix?
Hi Kathleen King - Typically when the error code P1 displays on panel it indicates that the unit has a sensor error. I would recommend contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire FAP094P1Z Portable Air...
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Protemp Sun-Stream 60,000 btu heater won't light
my protemp sun-stream 60,000 btu wont ignite fan runs but igniter just makes niose
Oct 27, 2011 | Goldstar KG6000R Window Air Conditioner
Where do i find a compressor for a dometic a/c rooftop unit for rv
If unit has many years on it, you may find it cheaper in the long run to replace entire unit. By the time you pay someone to change it , with it being a closed system, installed valves to re-charge, etc., a new upper unit, is usually the better decision. Sorry. You won't need control box, ceiling assy .,etc., so it shouldn't be too bad. New lower amperage draw units are available as well but work just as good.
Aug 11, 2011 | Dometic Rooftop RV Air Conditioner
BASEMENT FLOODED NOW THE WATER TANK WON'T LIGHT WHAT CAN BE THE PROBLEM
Thermocouple could be corroded not allowing the millivoltage needed to keep the pilot valve open on your gas valve.( Change Thermocouple) Also could have air in the gas line from not being used for a period of time. ( Bleed Gas Line until air is removed) These fixes should only be performed by people competent in the operations of a water heater. Dangerous results can happen if not done right like carbon monoxide poisoning, fire, etc.
Jul 05, 2011 | GE Heating & Cooling
We have a soleusair portable heat pump air conditioner PH5(S) series. The tank full light is on and won't go off. We have drained the unit and still the light stays on. We are trying to use as a...
Remove the water tank and look or feel up to where the float is at and see if it is stuck in the raised position. This is what is keeping the light on and not letting the compressor start.
Jun 20, 2011 | Soleus Ph5-13r-35d Portable Air...
Panasonic 1200btu air conditioner
you must check the fuse of pc board.its a glass fuse and propably had burned,replace it,if the fuse is ok then is the varistor and you must get an expert to fix it.
Oct 01, 2008 | Panasonic CW-C60RU Air Conditioner
GE Profile ASM10AA Air Conditioner Logo
16 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
