Question about Bialetti Coffee Makers & Espresso Machines
The coffee will not pour even when the light is green?
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
I have B60... I have descaled it twice wit vinegar... water is coming out although not as fast as it should. Descaling light still on... what should I do?
Vinegar is really not good for cleaning coffee machines.
You should rather use acetic acid.
1) put 4 cups of water into the coffee makers tank.
2) pour 4 cups of acetic acid also in the coffee makers tank.
WARNING !!! ALWAYS pour ACID into WATER and NOT the opposite !!!
If you pour water into acid, it can explode and cause severe damages !!!
3) Let it run through the coffee maker.
4) pour hereafter water in the tank and let it run through 2 times.
If this does not help to decalc your coffee maker, it is time for a new coffee machine.
Good luck
Aug 22, 2011 | Keurig Platinum B70 Coffee Maker
Bunn CWTF15-APS Unable to hold 195 at the brew head
Yes it is possible to go the the next larger element.
Yes if the machine was plumbed there would be a difference in the way it brewed the water temp. if you look at the end hose in the pan from the solenoid, it takes a while for it to pour out 3liters.
Try using a different sprayhead(if yo;u are using a 6 hole try getting a 5 hole. That will constrain the flow of water a little more allowing the element more time the heat the water.
Apr 17, 2009 | Bunn CWTF 15-APS Coffee Maker
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Stopped making hot enough water
Hello. If the temp is coming out low, there are a few possibilities. You said the "green" light was lit, is this a ready to brew lamp? if so, your thermostat is indicating it is at temp, even though it is not. I would say that it has failed, and needs replacement. It could be it has overheated, and tripped the safety limit, the heater has failed, a wire burnt off, it would require checking with a multimeter to know for sure. Take it to, or call a servicer, and have it checked, if its commercial, you can find a servicer in the phone book, under "restaurant equipment repair".
Hope that helps, and thank you.
Jan 17, 2009 | Bunn CDBCF 15 APS Coffee Maker
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Water does not displace...
if you give us the make and model we'll see what we can find for you.
Jan 05, 2008 | Bloomfield 8571 Coffee Maker
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Pennywhistler
Pennywhistler
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
