Question about Pioneer PDP-5071HD 50 in. Plasma HDTV
Pioneer pdp5071flashing blue light tv will not turn on
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
My Pioneer Plasma tv turns on for a few seconds and makes a noise then turns off
set is in shutdown as it detects either a missing voltage or a short somewhere----repair in these sets is trial and error---check a few things and then begin replacing boards----an expensive situation and Pioneer is not exactly easy to get parts from on some models......
Mar 20, 2012 | Pioneer Televison & Video
Why will my pioneer pdp 6020 not power up?
make sure it doesn't have a vacation button underneath. I have had kids or movers inadvertently press that button and tv goes dead. outside of that. you have lost the power supply and will need professional help. pioneers are very sophistcated
Dec 02, 2017 | Pioneer PDP-6020FD 60 in. Plasma TV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
I have a Pioneer SD-P5185-K rear projector TV that has small lines across the screen and the color changes. Someone said they have a gel pack(?) that might need replacing.
ya i got the same tv and i see double picture on the bottom of th tv if i cover the blue light inside the tv the picture goes back to normal so my problem is with the blue canon inside the tv. is this exspensive to replace???? or fix
Apr 07, 2010 | Pioneer Televison & Video
I need a red green blue light bulbs for my pioneer
I suspect you're asking about the projection tubes. They don't all go out at the same time, there is some other problem. Also consider, you can almost buy a new TV for the cost of the tubes. I really expect you'll find the right answer in your owners manual. Look into the advanced settings.
May 18, 2009 | Pioneer Televison & Video
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Please help
Could also be the cable, set are now designed if no signal to shutdown, so first check media box by calling cable company and or replace and try another just to make sure.
Aug 27, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Open Questions:
Pioneer PDP-5071HD 50 in. Plasma HDTV Logo
27 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
