Question about Frigidaire GLWS1233A Top Load Washer
Water overflows on occasion water is possibly spilling over and after the spin cycle there is water still in the tub
  • Frigidaire Master
  • 5,323 Answers
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Posted on Apr 01, 2015
  • 3422 Answers
SOURCE: Front loader will not spin
You will have to get it repaired that's the only solution.
there being a bad connection wire between the motor and the control board.est the fuse(s) on the control board. If they are bad, then the control board is in need of replacement.
Goodluck,
Please don't forget to rate the solution
Posted on May 06, 2008
  • 10 Answers
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
Posted on May 02, 2009
  • 7 Answers
SOURCE: Water remains in tub after spin cycle
Hi, a small amount of water in the tub is normal, between the inner and outer drum. As long as it's below the inner drum you're ok. If it's a front load this is a common smell. Just make sure you dry the rubber seal and leave the door open a little to allow air to circulate through the washer.
Posted on Sep 06, 2009
mgprice
  • 744 Answers
SOURCE: Washer runs fine until spin cycle--will not drain,
Hello, This is going to be one of 2 problems...either your drain filter is clogged or your pump is bad. Take off the lower panel on front, Behind this panel you will find what looks like a gas cap to a car. Unscrew this gas cap(have some towels handy to mop up water) remove the drain trap (filter) you should see alot of debris,coins maybe a sock blocking it...clean out the trap and replace. If this does not fix the problem replace the pump, although it sounds like it's humming it may be siezed or impellers might be broken. The pump should be located right next to the drain filter at the front of the machine. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Posted on Sep 09, 2009
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Set dial and water overflows, doesn't stop sending water in tub, No spin cycle
The water level sensor is faulty and so it does not switch even with water level coming to the set level. Unless the water level switch is triggered the water inflow will not stop because the inlet valve will not cut off.Remove the water level sensor and check if the diaphragm is working , if not it must be replaced.
Mar 13, 2012 | Washing Machines
Set it going, fills up ok, goes through washing cycle but after spinning and then filling up for next cycle it overflows
Rather hard to understand your problem from the wording in the question but what I understand to be the case is that your tub fills up with water and overflows after the cycle is finished. Perhaps overnight water slowly fills the tub. This is due to the water inlet valve not shutting off all the way. The Inlet valve assembly needs to be replaced.
Apr 27, 2011 | Washing Machines
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
It overflows water because it doesn't spin it out on the spin cycle
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Aug 21, 2009 | Washing Machines
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
Washing tub overflows.
your water level switch is operated by air pressure in a line that comes from the bottom of the drum up the back and into where the timer and water level selector are it can be adjusted but if you don't know how you'll have to have someone fix it for ya
Apr 03, 2009 | Maytag MAV6300 Top Load Washer
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Overflow
If you unplug the machine and the water still comes in, you have a bad Water Inlet Valve. If when you turn the machine on at in overfills and you can stop the water by turning off the washer timer then you have one of a couple possible issues.
First, you pressure sensing tube could be clogged
Second, you just plain have a defective pressure sensing switch.
If you have anymore questions, feel free to comment back.
Thank you
Mar 26, 2008 | Hotpoint VBSR3100D Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
