Question about Power Acoustik Performance Teknique ICBM-DTACH
I need the diagram to the wiring harness behind the in dash
2000 expediton bower motor comes on high when off radio and wipers flash on and off what exactly should we fix
It sound like you have a wiring problem somewhere behind the dash an the only way to know what to fix is by trouble shooting . Find wiring diagrams for the wipers , radio , blower motor an see if they share connectors in the wiring harness or see if wiring is rubbed through . You may have to take the dash apart to get at the harness . Go to you tube an check out some basic electrical trouble shooting videos an how to read wiring diagrams , an you mite also check out how to use a DVOM -digital volt ohm meter . You mite also have the body control module checked for codes , because the wipers are monitored by it. It's actually called a GEM - generic electronic module . It's not that easy , What Exactly should we fix ! Your best bet is to take it to a ASE certified repair shop or a automotive electrical repair shop.
Dec 02, 2015 | Cars & Trucks
Need wiring diagram for dash lights
all the plugs should only go to one place you shouldnt be able to hook anything up in wrong place stretch harness out across where it goes start at the end and go from there u can do it
Sep 06, 2012 | 1991 Nissan Pathfinder
I'm trying to install a Tekonsha trailer brakes and need the wiring diagram
The controller should have wiring diagrams with it. Also try http://www.etrailer.com/faq-wiring.aspx. The truck should have a harness that plugs into the factory harness under the dash. The harness paperwork will describe where it plugs into and what wires go where along with fuse location. If you don't hav the harness, you can get it from the dealer or the site listed above.
Feb 03, 2010 | 2003 GMC Sierra 2500HD
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Need a stereo wiring diagram to reinstall factory stereo in my 93 toyota windom
You shouldn't need a wiring diagram, your factory plug should still be in behind the aftermarket stereo harness, unplug the aftermarket harness and your factory plug plugs directly into the factory harness.... hope this helps..
Sep 21, 2009 | Car Audio & Video
Install alarm system
Battery- RED RED (+) IGNITION SWITCH HARNESS (2 CONST WIRES)
Ignition 1- PINK (+) IGNITION SWITCH HARNESS
Starter 1- YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger- WHITE (-) SMALL HARNESS BELOW ASHTRAY
Trunk Trigger- RED/BLACK (-) AT TRUNK LIGHT
Parking Lights- BROWN (+) BEHIND FUSEBOX UNDER CONSOLE OR SWITCH
Power Unlock- WHITE (+) POSITIVE TRIGGER OR DRIVERS KICK PANEL
PowerLock- LIGHT BLUE (+) IN CENTER CONSOLE "BEHIND FUSEBOX"
Apr 12, 2009 | Vehicle Parts & Accessories
Car audio wiring diagram for 1998 volvo s-70
CLICK HERE for your vehicles full service manual. If you are cutting wires.
Be warned your vehicle has a factory amplifier installed, and needs to be bypassed to hear the speakers if you are just wiring behind the dash.
Metra makes a harness you install on the aftermarket radio, then simply plug into the vehicle's harness.
All the wires are labeled for easy installation.
70-9220 is the metra part number. Click on the number to see an eBay auction.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 09, 2009 | 1998 Volvo S70
92 240sx dash wiring to sr20 ecu harness diagram
i knw how but i dont have wiring diagram.can u send me a copy so that i can explain to u
Mar 15, 2008 | Car Audio & Video
Power Acoustik Performance Teknique ICBM-DTACH Logo
21 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
