Question about Power Acoustik Performance Teknique ICBM-DTACH
Wiring harness Correct wiring on harness
Want to hook up radio. Bought correct harness. NO power to radio that works. Checked fuse and is ok. What next?
the wiring could be different,, hang on a sec ... here, check this link for the wiring colors and what they go to,, http://www.installdr.com/Harnesses/Toyota-Wiring.asp
Aug 26, 2011 | 1997 Toyota Corolla
Wiring problem with sony explode cd player and 07 dodge ram 1500 wiring is correct i think but it doesot turn on
First, did you use a wiring harness? If not, undo your install and replace the factory Harness in the vehicle. You can purchase a wiring harness for about $10 that you wire to your radio. This allows you to just "plug" the harness into the vehicles stock harness. If you have hardwired your radio you run the risk of frying your entire electrical system. Hope this helps.
Aug 23, 2011 | Car Audio & Video
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
My fuse for the fuel pump keeps blowing. the fuel pump was replaced. it was intermitant now as soon as you put the fuse in it pops. Short in the wiring somewhere?
When the fuel pump is replaced, often the correct wiring harness needs to be spliced in. The original wiring harness was more than likely reused. It is very possible the wiring harness is the cause for the short. Other than that, check where the wires go from the fuel pump wiring harness to the connection to where they go back inside the car. Corrosion is often another problem.
Feb 09, 2011 | 1994 Pontiac Grand Prix
When replacing the alternator on a 1992 nissan pickup I found an extra wire and quick connect in the wiring harness in the same general area as the alternator wiring. Please correct me if I am wrong. There...
in every automotive wiring harness there are extra wires, the wiring harnesses fit all the trim levels and all the special options that are avail, so one truck may not have a certain option and another does, all the connectors are there on both trucks, it is far cheaper to just build one harness than many for each level of trim or installed accessory.
Mar 03, 2010 | 1992 Nissan Pickup
Need to find a wiring harness
I would need further information: What most people do not realize is that a wiring harness is not a "one size fits all" thing. There are two harnesses that you may need.
To remove your factory car stereo and install a new aftermarket car stereo there are wiring harnesses for most cars that will plug right in to the wires from your old factory radio.
For that, you will need to buy the correct wiring harness for the year and make of your vehicle. Say, for example: 1987 Toyota.
Then there is a wiring harness for the specific car stereo. You will need the make and model number of the unit itself. Example: JVC model KD-AVX77.
Jul 24, 2009 | Car Audio & Video
I am trying to wire a sony xplod deck to my 2001 altima and need to know which wires connect to each other and steps of doing that.
Hello charlieramir,
The wiring color code for the 2001 Altima can be found here. Your Sony deck should have come with a wiring harness and an installation sheet (or a page in the user manual) that shows the color and function of each wire. You simply match up the functions of each wire on the harness with the appropriate wire on your vehicle.
A simpler and more professional installation is achieved by using a vehicle-specific wiring harness that plug into your Altima's wiring. Such a wiring harness allows you to make all of the connections while seated at the dining room table or other well-lighted location instead of the limited space area behind the dash. The Scosche NN03B/NN03 seems to be the correct harness for your Altima.
Hope this helps.
Jul 02, 2009 | Sony Car Audio & Video
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Power Acoustik Performance Teknique ICBM-DTACH Logo
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
