Question about Exercise & Fitness
Jazfit treadmill manual
Hi I have a jazfit T5P treadmill. Turn it on and the display panel lights up as it should howevr when i press the start button the timer starts counting and it beeps as it should but the machine wont start. E1 is in the timer display. I dont have a manual and the last itme i used it all worked fine. thks
  • 4 Answers
SOURCE: there's power but the machine itself won't work.
Hi, check if it is possible: main fuse in electronic board, normally all the board has a small relay, so when treadmill is on 4 or 5 seconds relay sounds with a click, if you press start and treadmill doesn´t move could be a problem with PMW circuit, MOSFET, Diode, diode zener and small transistors.
Best regards.
Posted on Nov 05, 2009
  • 64 Answers
SOURCE: Life Fitness T3 treadmill won't turn on. Power
Could be. If you had to take it apart, I would definately check the wire harness connection. Also if there are bolts that were removed, check to make sure none of those pinched the harness when reassembling.
Posted on Nov 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Posted on Jun 13, 2010
  • 33 Answers
SOURCE: Tuturi J661F stopped working - Error E1
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 14 Answers
SOURCE: after starting the treadmill 10
Check to see if your unit has an elevation motor with an 8-pin connector. If so, look for a tiny pot on the controller board and turn it about 25% to the right, with power off to unit. Turn tread on and try again ;o)
Posted on Oct 25, 2010
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Jazfit txo
see the video and proceed according. Lube the rollers bearing front+back with silicon or wax( depend of your mark, model) read your owner manual.
God bless you
Oct 18, 2013 | Icon Epic T60 Treadmill
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Machine shuts off- says LS
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
Sep 19, 2013 | Bowflex Exercise & Fitness
Jazfit T38R Incline up button beeps but doesn't do anything.
Dear Sir:
1(any signal from the console which could be a damaged cable 2(or the console itself has failed. 3(motor control board may have failed from a worn treadmill belt and deck 4( the motor may have burnt out. 5(potentiometer geared to the motor so the console knows what height the incline is at.6( gearing can slip, giving the console.
RUN THE software calibration for Help and trouble
see my personal TIPS for HELP
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
Hi..I recently bought a jazfit 5003 secondhand. It worked beautifully for a week. I turned it on today..but the console doesn't turn on. Any ideas?
19 Excahange the batteries old by new ones.
2) Tight the flexible cable for keypane vs display board
3) Tight the connector from display board to lower board.
4) Adjust the sensor reed switch bh 1/8" as show the diaigram
5)lsee the power output from main motor board is supplyin to display board the +5VDC.
See the block diagram for easy diagnostic and fix it.
sincerely. Merry Christmas
ernesto cuadra
Managua, Nicaragua.
Dec 22, 2011 | Exercise & Fitness
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Exercise & Fitness Logo
19 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
