Question about Epilady Health & Beauty
HOW TO USE CABLE PMKN4115A - Epilady Health & Beauty
Tach quit working an speedometer goes crazy what would cause
vss has probably gone bad. vehicle speed sensor ( vss)
Apr 24, 2015 | Cars & Trucks
Tip
How to connect and record on a VCR when you have a Digital Cable Box.
Do you want to still be able to use that trusty ol' VCR to be able to record your TV shows but can't seem to do so now that you have gotten a Cable Box?
Well here are some simple tips on how to connect all the components and not compromise the quality of the incoming signal of the cable signal feed.
First here are the cables you will need.
3 sections of Coax cable (preferably RG-6 quality)
or
2 sections of Coax cable (preferably RG-6 quality)
1 RCA cable (Yellow/Red/White)
Now here is how you will need to hook up the cables properly.
1) Connect one Coax cable to the incoming cable signal feed. Usually a screw on connector on the wall or line coming up through the floor.
Now connect the other end of this cable to the "Cable in" or "Input" located on the Cable box.
2) Now, connect one end of another Coax Cable to the "TO TV" or "OUTPUT" on the back of the Cable Box. Now connect the other end of this cable to the "CABLE/ANT IN" or "INPUT" connection on the back of the VCR.
3) Now, connect the last coax line from the "TO TV" or "OUTPUT" on the back of the VCR. Now connect the other end of this cable to the "Cable IN" on the back of the TV.
***** ALTERNATIVE OPTION FOR THIS FINAL CONNECTION******
Using the RCA cable connect to the "VIDEO OUT" RCA connections on the back of the VCR and connect the other end of this cable to the "VIDEO IN" on the back of the TV.
Now this is how you will need to set your VCR and Cable box to make your recording.
1) Tune your VCR to Channel 3 or set your timer to record Channel 3. (The actual channel you are going to be recording is controlled by the Cable Box)
2) Tune your cable box to the channel you wish to record.
*** Note: Some cable boxes have an auto tune feature that will tune your cable box to a channel while you gone. Contact your cable provider to see if this is available on the model that you have***
on Jan 09, 2010 | Televison & Video
Interior blower only blows up to warm on 1997 A4 2.7ltr
Check the blend door cable for proper attachment to the control panel and to the blend door. Try opening the door manually to see the you can get hot air out. If not, the door may be broken inside the heater box. If yes, correct/adjust the cable attachment for proper operation.
REMOVAL & INSTALLATION
1990-97 Passat Models
Install the cable ends marked with a white or blue band to the control head assembly. The cables must be attached to the control head before connection to the system air flaps.
  1. Remove the climate control head from the center dash assembly to access the control head cable ends.
  2. Remove the lower dash panels as necessary to access the cable lever arms.
  3. Attach the airflow distribution cable (cable 2) to the airflow distribution knob's lower control lever.
This cable can be identified as follows:
Operates the mode/central air flap Cable has a black sleeve and is 25.0 inches (634 mm) long Cable is marked with a white band
  1. Press the cable's sleeve against the control head stop and install the retaining clip.
  2. Attach the temperature control/air blend cable (cable 3) to the air temperature knob's control lever.
Operates the temperature control/air blend cable air flap Cable has a blue sleeve and is 21.0 inches (535 mm) long Cable is marked with a white band
  2. Attach the airflow distribution cable (cable 1) to the airflow distribution knob's upper control lever.
Operates the footwell/defroster air flap Cable has a black sleeve and is 37.5 inches (954 mm) long Cable is marked with a blue band
  1. Install the cable such that the blue band is over the retaining clip mount and install the retaining clip directly over the blue band.
  2. Install the climate control head.
  3. Set the air flow distribution knob to defrost.
  4. Connect the longest airflow cable (cable 1) to the footwell/defroster flap lever on the heater's air box.
  5. Press and hold the flap's lever toward the retaining clamp perch and install the cable retaining clip.
  6. Set the airflow distribution knob to the Vent position.
  7. Connect the short airflow cable (cable 2) to the central/mode flap's lever.
  8. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of both air flaps making sure they can be heard contacting their stops.
  9. Set the temperature control knob to full cold.
  10. Connect the blue-sleeved cable (cable 3) to the air blend/temperature flap's lever.
  11. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of the air blend/temperature flap making sure it can be heard contacting the stops.
Fig. Side view of the control head and cable location. 1. Footwell/defrost flap cable-2. Air distribution cable-3. Temperature control flap cable
Fig. Temperature flap cable location and adjustment
Nov 24, 2011 | 1998 Audi A4
How to change clutch cable for 78 suzuki gs750
Remove the gas tank then run the new cable along side the old cable. Unhook the old cable at the engine then hook up the new cable. Now remove the old cable from the bike. Give the cable adjusters all the slack you can get then hook the cable into the clutch handle. Pull the outer cable outward and hook the end of the outer cable on the outside of the adjuster. Pull the lever in all the way then release the lever while pulling on the outer cable. This should allow you to snap the cable end into the adjuster fitting. Below is a generic photo. Please rate my answer. Thanks! tombones49_47.gif
Apr 01, 2011 | 1978 Suzuki GS 750 E
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
My gear cable has snapped - frayed at the changer end, & I need to push the frayed end out to replace the cable, & I am having difficulty. Help please
Get a pair of dikes to cut the frayed end of the cable from the cable, then the cable will slide out of the cable housing. If you have jammed the frayed end of the cable into the cable housing and you can't get to the other end of the cable to pull it out, use a clothes hanger to push the cable out.
Nov 25, 2010 | Cycling
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
Replacement accelerater cable on focus 02 reg
you may have a badly carboned throttle body that needs cleaning with carb cleaner.
If cable:
Accelerator Cable —1.8L/2.0L Removal
  1. Disconnect the accelerator cable.
    1. Remove the accelerator retaining clip.
  2. Detach the accelerator cable from the bracket.
    1. Rotate the cable to release.
    1. Detach the accelerator cable.
  3. Remove the footwell trim panel.
  4. Disconnect the accelerator cable from the pedal.
  5. Attach a draw cord to the accelerator cable to assist with installation.
  6. Remove the accelerator cable.
Dec 13, 2008 | 2002 Ford SVT Focus
Noisy speedometer
The click you are hearing might be a dry speedometer cable. Applying grease to the inner cable will most likely help this problem. The problem is getting to the cable behind the speedometer/dash panel. You can also get to the cable from under the truck. if you crawl under the truck and look at the smaller end of the transmission, you will see the cable screwed into the tail piece of the transmission. Remove the cable from the transmission and pull the inner cable out of the outer cable. The inner cable is what spins and causes the speedometer to turn. Take regular wheel bearing grease in the palm of your hand and slid the inner cable through the grease then put the inner cable back in the outer cable. When the inner cable gets to the back of the speedometer, you will have to slowly turn the cable and give a slight pressure inward to seat the inner cable into the speedometer.
Hope this helps.
Good Luck
Nov 14, 2008 | 1996 Toyota Tacoma
Health & Beauty Logo
26 people viewed this question
Top Epilady Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Epilady Health and Beauty Expert? Answer questions, earn points and help others
