Question about Philips 42TA648BX 42 in. LCD TV
Tv turns off by it self.sometimes i can turn it back on some times i cant
Shuts off by it self.when i try to turn it back on it comes on and stay on a while maybe 15 mins.sometimes i turn it on and i turns off right away .could it be over heating from dust binging inside of it if so what is the fix thanks .
SOURCE: Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Posted on Feb 11, 2008
ser71
  • 818 Answers
SOURCE: Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Posted on Mar 05, 2008
mohammed387
  • 1952 Answers
SOURCE: menu keeps coming on .
First check for a short in all power semiconductors diodes, transistors, SCR, etc. Replace defective parts. The FBT coould also be defective. Check the voltage on each of his pins.
TV Repair
Posted on Oct 17, 2008
  • 44 Answers
SOURCE: Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
SD Tech
  • 14553 Answers
SOURCE: the tv will not turn on with first try, have to
I think I know what your problem is.
I am going to give you an explanation in simple terms. I suspect (I have seen the exact same thing several times) that you have puffed up caps in the power supply.
They are also called electrolytic capacitors.
All LCD, PLASMA, and even desktop computers use a power supply that is up and running 7/24 even if the unit is not turned on.
It is called a STANDBY power supply---I am going to take a photo so you know what the suspected parts look like and attach it here.
The reason this happens is many companies cut corners here--these caps are rated at a specific capacitance and WORKING VOLTAGE--the working voltage is the max voltage the part can tolerate over time.
The way they save money is most of these power supplies in STANDBY are about 8 or 9 volts and they put caps rated at a MAX of 10 volts--after a year or two the caps dry out inside and the tops of them puff up--having trouble getting to turn on--having to unplug it and try several times to get it on is a dead giveaway this is what is wrong---as time goes on it gets harder and harder to get it to come on.
The reason companies do this is if they make 10,000 sets and use 10 volt caps instead of 16 or higher voltage rated caps---they save a nice piece of money---they do not care if it only lasts a few years--they will be clear if it makes it through the 1 year warranty.
If someone opens the set and follows the power cord it will take them to the power supply board. Look at the two photos---notice the one with the silver top of the cap---bad ones will be clear to see---the top of them will be puffed up and NOT FLAT.
If this is what is found you have two choices--replace the caps--parts cost should be under 30 dollars for the parts OR REPLACE THE POWER BOARD--the board will be EXPENSIVE---confirm actual full model number and I will try to get you a part number and price for it.
The new board will work but have the same substandard caps in it and in a few years fail the same way.
Sooner or later when enough caps puff up---the set will not turn on at all.
I just fixed one of my desktop computers with this exact same problem--parts cost me 12 dollars and I upgraded from 10 to 16 volt caps---50% increase in ability to handle the voltage.
I have seen this in dozens of newer sets.
Let me know if I can help you further and if this information helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 27, 2009
Testimonial: "awesome, thank you so much!!"
Hard to get tv to stay on. comes on then shuts right off??
I have a very similar problem with my same tv. I know you posted this a while ago but if u solved your problem I would love to know how to fix it, mine just went out with that same problem. And vice versa if I get mine fixed.
May 15, 2010 | Toshiba 65H84 65" Rear Projection HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
Panasonic TH50PX85U power shuts off and won't come on.
power board failure, common in this model, replace power pcb then check VS and VA voltage could be X or Y driver causing power pcb to fail.
Aug 09, 2009 | Televison & Video
Tv comes on then just shuts off will turn right back on
hello it sound like theres may be a dry joint probably in the power supply you would need a strong light and a magnifying glass and soldering iron and some solder
shaun
Apr 08, 2009 | Hitachi 50GX49B 50" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Tv turns its self on or off at times
I tried to unplug mine for awhile then plug it back in that worked for awhile now it won't come at all. Hope this helps abit, although i'm sure your like me and have tried it all,8)
Jan 17, 2007 | RCA 27F650T 27" TV
Philips 42TA648BX 42 in. LCD TV Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
