Question about Air Conditioning Evaporator 1995 Peterbilt All Peterbilt Trucks
95 peterbilt 3306 oil light stays on - Air Conditioning Evaporator 1995 Peterbilt All Peterbilt Trucks
    Problem Solver:
  • 5 Answers
I don't have any experience with peterbilt trucks, but I have seen this problem several times on several different vehicles with both lights and gauges. Each time but once, it was the oil sending unit. The one time it wasn't the oil sending unit it was the oil pump had went out. I'm not sure this will help and I don't know how to check the oil sending unit. I just replaced the unit and that fixed the unit all but that one time. You can pull the unit and put an oil pressure gauge on it to check the oil pressure but I didn't have one so I just replaced it. I don't know if this helps but you're welcome to the info.
Posted on Jan 17, 2016
I've got a 2013 Peterbilt 388 that is getting 80psi constant pressure through the brake application/stop lamp switch air line. At 120psi in both tanks, the application pressure gauge is reading 80psi and...
make sure you haven't cross connected the glad hands if you're hooked to a trailer.
You could have a diaphragm bad on one of the wheels.
Do you drain oil/water a couple times a day to keep system clean? Add alcohol especially if it's already freezing in your area.
Nov 16, 2017 | Cars & Trucks
Why does the oil buzzer stay on on a 94 peterbilt when not started
If it' an oil presume sensor, it will go off once oil presume built up.
Dec 02, 2016 | Cars & Trucks
What is the valve clearance on cat 3306 engine
more complete answers about the 3306 engine
and how to dos are on the web
3306 engine cold is .015 intake and .025 exhaust.
Sep 09, 2016 | Cars & Trucks
How do you do a regin on the peterbilt?
Your engine should regin automatic. If regin light stays on for more then a 5-10 min. You got somthing wrong and you need to see your dealer.
Oct 11, 2014 | Cars & Trucks
The back red lights of my 2009 peterbilt stay on even if the engine is shutdown.. what can possibly be the problem?
check out the brake light switch either under the dash at the top of the brake pedal or on the brake valve body. It is probably stuck in the on position
Dec 05, 2013 | 2000 Chevrolet Cavalier
I have a 95 grand am se 2.3 liter the other day my low coolant light came om i pulled over emediatley it was low i filled it and have been checking every time i go anywhere it is full and my low coolant...
You may have to reset it by putting in a code. You can find the code in your owners manual. In our Grand Am we have to reset the Check Oil light after we change the oil. For the oil light it is something like press the gas peddle in 5 times within 30 seconds....something like that. Good luck
Aug 14, 2011 | 1995 Pontiac Grand Am
How do i reset the oil light on my 95 fleetwood cad
1993 BROUGHAM & 1993-96 FLEETWOOD
Oil Life Indicator
1. Oil life indicator will display CHANGE OIL when oil change is needed, based upon engine oil temperatures and driving patterns. After changing oil, reset
oil life indicator.
2. To reset, turn ignition switch to ON position. Do not start engine. Fully press and release accelerator pedal 3 times within 5 seconds. If CHANGE OIL light
comes on and stays on for 5 seconds, it did not reset. Reset system again.
Jun 08, 2010 | 1995 Cadillac Fleetwood
95 chevy lumina 3.1 Dashboard lights stay on
usually, this is an ignition switch problem.
Oct 13, 2009 | 1995 Chevrolet Lumina
Air Conditioning Evaporator 1995 Peterbilt All Peterbilt Trucks Logo
51 people viewed this question
Top Air Conditioning Evaporator Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Air Conditioning Evaporator Heating and Cooling Expert? Answer questions, earn points and help others
