Question about Brookstone Pure-Ion UV Air Purifier
The machine will not start after the preset was closed
The machine will not start up again after reset was closed
Does check engine light reset after replacing faulty gas cap.
A check engine light will not clear itself! The light will have to be code read and reset using a OBD code reader.
Feb 26, 2015 | AEM Brute Force Intake 2003-2005 Ford...
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Apr 29, 2012 | Ecoquest Flair Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 09, 2010 | Filter Queen Defender Air Purifier
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
HOW DO YOU RESET MACHINE AFTER INSTALLING NEW FILTER
Try unplugging it, then wait a few munites,then plug it in again.
If that does not do it, see if the switch has a reset position and they turn it to that point.
Feb 01, 2010 | Honeywell Air Purifiers
Turn off reset button
IF RESET DOES NOT WORK DON'T WORRY
AS LONG AS YOU REMEMBER TO CHANGE
THE FILTER. CHARCOAL WHEN DIRTY AND
HEPA ONCE A YEAR OR SO.
Mar 19, 2009 | Whirlpool Whispure (45030) Air Purifier
Bionaire filter replacement- reset indicator
It worked - the solution to press sleep and the power button simultaeneously worked! Air cleaner then reset to 99%. Thank you Harbourman!
Oct 31, 2007 | Bionaire BAP1175-U Air Purifier
My remote control stopped working
i do apologize for the inconvenience the only thing that i can suggest is the that whole unit will need to be reset. so the machine can connect again with the remote. also make sure that batteries are fully charged. If that doesn't work please let me know.
Oct 19, 2007 | Bionaire BAP1500-U Air Purifier
Brookstone Pure-Ion UV Air Purifier Logo
35 people viewed this question
Top Brookstone Air Purifiers Experts
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
