Question about Lite On LVW-1105HC DVD Recorder
Door want open most of the time/lots of problems/i want to burn it.
GE dryer model dwsr405eb0ww has intermittent heat problem associated with centrifugal motor switch. Interior drum light goes off with door open when centrifugal switch disengages. This is intermitte
First thing I would do is un-plug the product and remove the line cord access plate and check the terminal block/cord connections, a lot of times the installer of the product does not get the terminal block 'nuts' tight enough and it either burns up or cause erratic operation. If this checks out ok check your home electrical supply system.
Jan 09, 2015 | GE Dryers
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Is there a manual for an Acorn ranger wood stove
I haven't found one.... What i did was put a paint-marker line on the closed position.. Get a decent fire going with the door cracked open about 1" (5-10 min) - set both dampers to 1 full-turn open and close the door. Once it starts kicking heat (another 5 to 10 min) reduce it to 1/8 to 1/4 turn open. Seems to burn great like this. I use mine in the shop so i'll also thrown green and punky wood that I won't burn in my house in the belly of this beast and load it up at the end of the day and then close it down completely. It will burn the green / punk wood all night and will still have lots of coals after 12 hours.
Nov 19, 2010 | Heating & Cooling
I repairewd the burned open relay and after seveal
Being that the number one problem with a refrigerator is that it stops cooling, it would be impossible to determine your problem. its possible the timer is bad, but there are about 50 other things it could also be. Keep in mind, if you dont know what you are doing, you could end up costing yourself a lot more money and possibly cause serious injury to your self.
Feb 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
Installed a new dvd burner for Hp computer. Running Windows XP. Installed Nero 8 Software. Door doesn't always open when button is pushed or after burning a dvd. Computer also has another cd/dvd drive....
it has to do with a new hardware installation process....check IDE cable that they are correctly connected and try to check system setup so that the CMOS identifies both, primary & secondary devices....if not, u need to install a driver for the newly installed one....
Oct 05, 2009 | Computers & Internet
Kenmore Electric Range Slide in....beeping while not in use
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
Jan 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Lite On LVW-1105HC DVD Recorder Logo
43 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
