Question about Electrolux Ovens
Frigidaire lr13824 Oven does not work
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire classic oven will not work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 05, 2011 | Frigidaire Ovens
I have a frigidaire oven and every thing works but the oven wont light,the glow plug come on but just wont lite
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Feb 12, 2011 | Frigidaire FFEW2725LB Oven
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
Frigidaire Oven
DO NOT USE THE OVEN until you replace oven control
thank you...garing
l
Aug 06, 2009 | Frigidaire FGB24S5A Gas Single Oven
Frigidair Upper Oven is not working, wife cleaned oven, when
Screen display on Frigidaire wall oven not working
Jul 05, 2009 | Frigidaire Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Frigidaire gas oven not working
when the power returned there would have been a high voltage which would have blown out the fuse cange the fuse and on it
Jul 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven electric
i have a frigidaire elite convection oven,older, the elements work but the convection oven will not turn on - what should i check?
Jan 13, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
29 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
