Question about HP Computers & Internet
P6674y will not start - HP Computers & Internet
What can I do to fix the sound on my HP Pavilion desktop model #P6674Y (4 years old)? The only sound is a scratching noise. I thought I needed a new monitor, but that is not the problem. I've had tech...
Go into control panel and search for sound icon.there are several things you need to check.is the mute box checked anywhere in the drop down menus.usually you can control this via keyboard using the fn button along with the blue icons on the top row of keyboard.but if you are in control panel in the sound settings check all the sliders are up and check tick boxes.there is an area whereby you can test the sound output.if there is no sound coming after you check then try to use earphones in the socket.if they are working it could mean the onboard speakers are faulty.i am assuming the sound card is okay the drivers for the sound card are okay.
lastly if still no sound you might try going into device manager .....click the windows key and pause break button together ...look for device manager....look for the sound card....uninstall it....then rescan for hardware changes...that will force the computer to reinstall the card which usually resets audio settings to default.hope this was helpful..good luck.
Feb 23, 2015 | HP Computers & Internet
Volvo v40gdi sometimes won't start but starts fine from cold when trying to start it chokes and struggles if I remove air filter assembly it starts fine,
To troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Mar 14, 2013 | Cars & Trucks
No wired network connection
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps
Nov 27, 2011 | HEWLETT-PACKARD Pavilion p6674y...
No video. when computer is turned on the screen displays the name, "acer", in this case, then goes blank saying, "no signal"
have you checked all of your cables from the computer to the monitor, to make sure there's a secure connection?
Sep 22, 2011 | HEWLETT-PACKARD Pavilion p6674y...
Can I record from VCR directly to my computer?
Yes, with the help of a capture device. Something like
http://www.amazon.com/EasyCAP-DC60-Creator-Capture-High-quality/dp/B002H3BSCM
Sep 01, 2011 | HEWLETT-PACKARD Pavilion p6674y...
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
