Question about Singer Inspiration 4220 Mechanical Sewing Machine
BOBBIN FILLING AN THREADING
SINGER INSPIRATION 4220 MECHANICAL SEWING MACHINE NEED MANUAL HOW TO FILL BOBBIN AN THREAD PROPERLY
  • Singer Master
  • 1,388 Answers
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Posted on Feb 14, 2010
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
THREADING AND BOBBIN LOADING HOW?
http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf or http://www.youtube.com/user/SingerSewingCompany or http://www.singerco.com/sewing-resources/operation-basics
Feb 16, 2014 | Singer Inspiration 4220 Mechanical Sewing...
Bottom thread: you can pull right out of material after stitched.
Very vague question... well it's not even a question. If the bobbin thread is straight with little loops... your top tension is too loose. Tighten it.
Sep 24, 2013 | Singer Inspiration 4220 Mechanical Sewing...
Bottom thread pull out after stitched What is my mom doing wrong
try a new needle
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
try adjusting the top thread tension
if these suggestions don't help then it would be a good idea to have the machine checked
Singer 4220
try changing the needle
rethread the machine top & bobbin
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint & thread
May 02, 2012 | Singer Inspiration 4220 Mechanical Sewing...
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
I've rethreaded the machine mulitple times and it keeps bulging up on the botton around the bobbin and I keep having to lift the small clip to reinsert the black part where it holds the bobbin. My thread...
Take a deep breath and read page 67 of your manual, it is your top threading that is causing the problem. On page 67 it gives troubleshooting hints, like making sure that you are holding the thread ends when you start to sew, look for a bent or burr on your needle. Replace needle. If, you do not have a manual go to singerco.com and download one for free.
I had the same problem last week and swore I had threaded my machine right, then I looked at my manual, whoa nellie!, I missed a guide and I have been sewing for 50+ years.
Sep 10, 2010 | Singer Inspiration 4220 Mechanical Sewing...
What bobbin should be used for a singer inspiration moder 4220
Normally it is a #15 or 15J. Your manual should tell you or you can go online at singerco.com and look under support for a free download of you manual. I checked the Singer site and you may have to have a "surefit" bobbin that is exclusive to Singer. You can call them at 1-800-4singer
Sep 08, 2010 | Singer Inspiration 4220 Mechanical Sewing...
WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD - HAVE NOW BROKEN TWO NEEDLES. THEY BEND AND SNAP AS IF THE MACHINE IS OUT OF SINK WITH ITSELF.MY MACHINE IS A SINGER INSPIRATION 4220 . (I DONT REALLY KNOW...
Make sure the needles are installed with the flat side facing the back of the machine.
Open the bobbin area and hand walk the needle down to see what it is hitting.
Check the bobbin case and shuttle to be sure they are in place.
Needles can also bend and break if they are too small for the thickness of the fabric.
Feb 28, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Singer 4220 bobbin thread wont raise
To learn how to solve the bobbin problems and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Oct 23, 2009 | Singer Inspiration 4210 Mechanical Sewing...
I have a singer-inspiration machine and it appears that the thread keeps getting caught up in the bobbin area so my thread birdnests. I am new to sewing and this is a new machine.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Aug 23, 2008 | Singer 7462 Mechanical Sewing Machine
Singer Inspiration 4220 Mechanical Sewing Machine Logo
94 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
