SOURCE: no picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
SOURCE: my pioneer plasma PDP 5060HD Media Center control
lenwas,
I have the exact same problem with the same model tv. It just stopped working, tv has no lights or evidence of power and the red standby light on the media center flashes without any other function potential.
I checked the internal tv fuse and it was measuring continuity.
If you figure anything out I'd be interested to hear it.
Tom
SOURCE: Pioneer PDP 4330HD display flashes red LED 4 times
Just seeing if you had resolved the problem as my mum's Pioneer PDP-433HDE which she bought back 2002 has developed this same fault.
It has been a perfect TV and done very well with plenty of good use, but I have a feeling the cost of repair - even if it is possibale will be costly.
Cheers
Nigel
SOURCE: Is my Pioneer 50" plasma PDP-503HDE HD ready?
Yes it is but upto 720P only. It is not full HD(1080P).
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
