Question about Schwinn Original Airdyne
My airdine bike is locked - Schwinn Original Airdyne
How do I remove the key assembly if the bike is in steering locked position?
Had a similar problem a couple of times, but not this model. The first time I removed the lock that locks the saddle down (same lock as ignition, Honda Wave 125) and took it to a locksmith who made a new key by looking down the barrel with a telescope type tool. He was good, even identified the bike that the lock came from.
The second time I took the whole bike along on the back of a pick-up and he made a new key the same as before.
The guy works from the pavement in Thailand. Hope you can find the same service where you live !!!
Jun 27, 2015 | 1997 Honda CBR 1100 XX Super blackbird
Which other years have the same lock set as a 2005 CBF600?
I'd try and ring your local bike shop to find out.?
or take the lock barrel out and get a lock smith to cut a key for it.
good luck........
May 19, 2014 | 2005 Honda CBF 600
Air lock and starting problems in karizma r bike
You need to be a little more descript . Is it still an air lock? ,is it fuel starvation?, is it a poor electrical connection?.......One thing is for sure Hari it WILL be something ridiculously simple, it alway's is.
Mar 13, 2014 | Hero Honda Karizma Motorcycles
My bike light are automatic on when its locked please give me solution and explain why this happen?
sounds like you are turning the key to the park position not the locked position...
Dec 12, 2012 | Bajaj Discover DTS-I Motorcycles
HOW DO YOU PUT THE BIKE IN THE STAND?
Do you mean a bike stand, that you lock it to? If so, simply follow these steps and you'll be ready to go in no time!
1. Get bike to rack
2. Get off bike
3. Stick wheel through gap in metal bars of stand.
4. Lock bike to rack, passing the lock THROUGH the frame of the bike, not just a wheel.
5. Grab your keys and head inside, your done!
Oct 04, 2010 | Cycling
I have a Burley Cub bike trailer. I'd like to be able to take the kids to the store and lock the trailer along with the bikes using a cable and heavy duty lock. How can I do this to secure the Burley Cub?
You will want to use two cables and two lock. Run one through the bike frame and one through the frame of trailer. More is safer when it comes to locks.
Jun 10, 2010 | Burley Cub Bike Trailer
My rm 80 1stand 2nd gear locks wheels
If your rear wheel is locked up in first and second gear with the engine running, this is not a good sign. Have you ever ran the bike without oil in the transmission? Every time I've seen this, the chain was thrown off the bike and it busted the cases. The oil leaked out of the cases and the transmission locks up. Generally, it locks in fifth gear but it could lock up in any or no gear.
Your problem sounds like something is wrong with the low gear-second gear "clutch gear". The clutch gear is gear that slides sideways on one of the transmission shafts to engage the proper gears. If the bike will roll when in neutral, these may be the only gears affected. If the bike will not roll when in neutral, your problem may be in countershaft. Either way, the transmission could be damaged.
Now, if you're talking about the rear wheel locking up if you try to push start the bike, this is because in low and second gear, there isn't enough mechanical advantage in the transmission to overcome the engine compression. Remember, you transferring torque through the transmission backwards when you try to push start the bike. Try starting the bike using third or fourth gear instead. Standing on the pegs and dropping onto the seat when you release the clutch helps.
Oct 26, 2009 | 2003 Suzuki RM 125
I forgot my code
I have the same issue. I just bought a bike and dug out my old bike lock from college. Obviously the codes I'd being using now are not what I programmed my bike lock originally with. Any suggestions??
I've been trying to listen to the lock when I rotate the numbers and crack the code. Not a fun task.
Sep 29, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Schwinn Original  Airdyne Logo
29 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
