Question about Joy Satellite M55 S3314 Laptop PC
Toshitba Satellite M55-S3314 Color Problem
My Toshiba M55-S3314 laptop has had many problems, but this is just one of them. Recently I started up my computer and noticed that the screen had taken on a blue hue with other random colors popping in at certain times. For instance, the white background now is light blue and my scrollbar has lines of small blue bots running down it. Also, my cursor seems to have a large white and gray shadow underneath it. basically, the everything I look at has had its color distorted. I can't figure out what is wrong. I've shut down and restarted m laptop and looked through the properties, but nothing has worked. Any advice?
  • 83 Answers
Re: Toshitba Satellite M55-S3314 Color Problem
Goto RUN under the start menu and run DXDIAG just as i typed it goto video and run the video test,if it passes your screen is bad if not re install driver if not foud find out who makes your video card and download it from them hope im hel that should work lemme kno if it didnt i may find you some more solutions
Posted on Oct 28, 2007
0 characters
3 Points
Remove laptop hard drive
under the laptop you should see a plastic door with symbols like a harddrive symbol, unscrew the door and unplugg the harddrive.
Apr 05, 2012 | Toshiba Satellite M55-S3314 Laptop
I have a toshiba satellite m55-s3314 and when I turn it on it stays stuck on the first screen and the laptop makes noises like it stuck
if it's making a clicking noise, like metal-to-metal clicking, then most probably your hard drive is failing. If this is the case, get the hard drive into a USB tray and get all your important data out of it. You'll have to get a new IDE/ATA hard drive for your Toshiba if you want to continue using it.
Jan 19, 2011 | Toshiba Satellite M55-S3314 Laptop
I recently purchased a Toshiba Satellite M55-S3314 from my grandmother, who had bought it for another grandchild. When I turn it on I am confronted with a password login. The grandchild cannot be contacted...
Download this ISO file (PCLoginNow) burn it to a CD
Boot from the CD and follow the onscreen instructions to delete the password.
Remember to check the box for Password is empty, and the Box for Password never expires.
When you reboot tap a key to bypass the disc check it tries to perform if you want a faster bootup.
Your password is now clear, you can safely enter Windows.
Oct 30, 2010 | Toshiba Satellite M55-S3314 Laptop
Any solution as to why my Toshiba Satellite M55 S3314 randomly shuts down even in less than 30 mins usage?
check that it is not heating up, on with the power supply ,download reginout if there are errors in os
Aug 26, 2010 | Joy Satellite M55 S3314 Laptop PC
How do i remove the keyboard on a toshiba M55-S3314 laptop?
You will need to use a pocket knife, or flat object to pry up and remove the plastic strip above the keyboard first. I'm pretty sure it is held in place by pressure only, no screws yet (see NOTE below). Once this piece is removed, it exposes two screws that hold the keyboard in place. Remove these screws, and you should be able to lift the keyboard from the laptop. Be careful, as the keyboard is still connected to the motherboard by a ribbon cable that needs to be disconnected. Once you release this cable from the motherboard, you should be clear to separate the keyboard from the Toshiba.
NOTE, if you are having trouble removing the plastic strip from above the keyboard, flip the laptop over and remove the battery. Look for any screws that may be holding it in place and remove those first.
Jul 21, 2010 | Toshiba Satellite M55-S3314 Laptop
I fomatted my laptop and after which i could not find some of the drivers.what can i do tog get them?
hey there welcome to fixya
try downloading this file on this site,sh,31205,221,19,.html
it is a driver detector and will hopefully yell you which drivers you need to download
thankyou for using fixya please remember to rate this solution
thnk you
magical nik
Jun 08, 2010 | Toshiba Satellite M55-S3314 Laptop
My toshiba M55 Satellite will not boot up. My
Take the hard drive out and see if anything comes up on the screen. If so, replace the hard drive.
Does the screen get any brighter when you turn on the laptop? If not, the lcd cable, or power inverter may have gone bad.
Did you have any blue screen of death errors, or any other kind of errors before the screen problem? If so, you may have bad memory. Do you hear any beeps?
Jan 14, 2010 | Toshiba Satellite M55-S3314 Laptop
Toshiba satellite m55-s3314 turns off as soon as it is turned on
Remove battery, press and hold power button for 5 seconds, reinsert battery and make sure it is securely in place
Jan 10, 2010 | Joy Satellite M55 S3314 Laptop PC
Joy Satellite M55 S3314 Laptop PC Logo
298 people viewed this question
Top Joy PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a Joy PC Laptop Expert? Answer questions, earn points and help others
