Question about Microwave Ovens
Panasonic nn sd677s
Ligt bulb replacement
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I need to find a
Generic replacement bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If you would prefer to order the original bulb, the best place to order Panasonic parts is Tritronics.
You can also call them at 866-779-5835.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacing bulb for microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You should be able to download your owner's manual from Panasonic.net by choosing your region & country, then Support.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: bulb replacement
You'll need to remove the outer cover (wrapper) to get to the bulb.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Posted on Jan 19, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Jan 23, 2009
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Hole burned in panel inside next to ligt
take it in for repairs or just replace it
Apr 26, 2015 | Sharp Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Changing ligt bulbin morphy richards 23L
Probably not that hard but you do have to take the cover off and do not go near the heating element as it is charged with electricity. Of course unplug before you do anything.
Dec 11, 2014 | Morphy Richards Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
GE JVM1640WB004 light bulbs break off when trying to replace them
GE uses a bulb that includes two flat pins. It looks like a bulb and removable socket, but it isn't. Just a way to cost you more. The bulb is removable from the top where it's mounted, and removed from the hole that it sticks vertically down thru. 1. You have to remove the unit cover to get to the bulb. 2. You have to unplug the connector to remove the bulb. 3. You have to squeeze two plastic pins, to extract the bulb from its location. This is not a common bulb; good luck finding one.
Nov 14, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
